HomeCommunityAI blog
June 10, 2026
Beyond the demo: Deploying and evaluating Open-Source AI workloads on an Armv9 Platform
Move beyond benchmarks with practical Armv9 Learning Paths for deploying, observing, and evaluating modern AI workloads at the edge.
By Odin Shen
Reading time 9 minutes
 As more open-source AI models move closer to real-world adoption, developers are changing how they evaluate edge deployment. The question is no longer simply whether a model can run, but whether it can be deployed reproducibly on a concrete platform, observed in practice, and turned into meaningful deployment decisions based on actual technical evidence.
For developers, the CIX Armv9 platform provides a practical environment for hands-on experimentation and reproducible deployment. With open-source toolchains and implementation-focused Learning Paths, developers can bring AI workloads emerging from China’s open-source model ecosystem onto an Armv9 platform. They can then evaluate the issues that matter most in edge AI adoption, such as memory capacity, model selection, and the trade-offs between performance and deployment requirements across different scenarios.
This article draws on 2 Learning Paths, using Mixture of Experts (MoE) large language models and multimodal inference as two complementary examples. Together, they show how deployment, observation, and optimization can gradually turn model experimentation into more concrete edge deployment evaluation.
Why edge AI evaluation cannot stop at “does the model run?”
During the current AI surge, platform narratives often lead with a familiar claim: a model has successfully run on a specific device. That result has value, but for developers evaluating edge deployment, it answers only the most superficial question.
Once evaluation moves into a real deployment context, the questions become more practical. How much memory does the model require? Is the deployment flow stable and reproducible? Do system resources stay within an acceptable range during inference? Is the model suitable for the target use case? If all we know is that the model produced an output once, most of these questions remain unanswered.
For edge AI, the real value is not a single successful run, but whether a repeatable technical path can be established. Developers should be able to deploy, observe, and compare repeatedly, building a clearer understanding of how platform characteristics, model behavior, and scenario requirements relate to one another. Only then does a platform become more than something that can run AI models. It becomes a platform that supports deployment decisions based on technical evidence.
That is why this article is not about an isolated demo. Instead, it focuses on a practical process: start with deployment and build understanding through observation. They then use those observations to identify optimization directions that support  edge deployment needs.
The CIX Armv9 platform as a practical starting point for deployment evaluation
For developers, a valuable platform is more than one that looks capable on paper. It is one that helps you get started quickly, reproduce workflows reliably, and generate useful observations throughout evaluation. From that perspective, the CIX Armv9 Platform can be seen as an Armv9 development platform that helps establish a deployment and evaluation baseline.
Beyond hardware specifications, its value depends on whether it is suitable for building that baseline. Developers can use a familiar Linux environment and open-source toolchains to deploy models directly on the board. They can verify whether models run stably, confirm whether workflows are reproducible, and observe whether resource usage remains within a reasonable range. This helps them identify factors that could affect future optimization and scenario fit.
This is especially important in edge AI projects. In many cases, early project stages are not about achieving the highest possible performance. They are about establishing a credible starting point. Can the model be deployed? Can the workflow remain stable? Is memory sufficient? Is this configuration aligned with the intended use case? Exploring these questions on an Armv9 platform helps developers make better optimization and model-selection choices later in the project.
This is even more valuable when the deployment flow is built on open-source toolchains. Developers are not limited to running a model into a closed system and waiting for a result. They can examine how the model is loaded, how it is executed, what runtime characteristics are worth observing, and which constraints may become relevant in later deployment stages. In this context, the CIX Armv9 platform is more than a system for running AI workloads. It is a practical environment for deployment assessment.
More importantly, the deployment and observation methods established on CIX also have the potential to inform work on other Arm-based edge platforms. That gives the platform value beyond a single validation exercise, helping developers build a more reproducible and extensible evaluation approach.
Starting with MoE deployment: observing large-model behavior and optimization directions on Armv9
As generative AI continues to evolve, MoE are becoming an especially important model architecture to watch. They use expert routing; instead of activating all parameters for every inference step, the model dynamically selects a subset of experts based on the input. This allows MoE models to support larger model capacity without activating all parameters at every inference step, while also exposing runtime characteristics that are particularly interesting to observe.
For developers, this is more than an architectural distinction. It directly affects how resource usage, inference behavior, and platform suitability can be understood during deployment. That is why MoE models provide a useful starting point for examining how modern large models land on an Armv9 platform.
Rather than focusing only on final outputs, developers can observe routing behavior during execution and understand how that behavior affects inference characteristics. These observations support deployment assessment by helping developers assess memory requirements, compare model options, and determine whether a platform can meet deployment requirements..
Using ERNIE 4.5 as an example, developers can follow the corresponding Learning Path to deploy this type of MoE model on the CIX Armv9 platform and use open-source toolchains to observe important execution characteristics. The value of this exercise is not simply proving that the model runs. It helps developers form a stronger understanding of what to observe when this class of large model is brought onto an Armv9 platform. They can identify patterns that may inform later optimization decisions, and evaluate whether the model is suitable for a specific edge scenario.
Starting with multimodal inference: building a reproducible workflow and deployment path on Armv9
For edge devices, multimodal inference is valuable because it more closely reflects how information appears in the real world. Many practical applications do not depend on a single data type. They involve text, images, audio, or the integration of signals from multiple sources into a more complete decision-making process. For this reason, multimodal models are becoming increasingly important in edge AI.. They extend model capability, and help developers evaluate requirements that are closer to real deployment needs.
For developer’s, the challenge of multimodal inference is not simply whether the model can execute. It is whether the full workflow can be built, reproduced, understood, and adjusted on a concrete platform. Once a model must process multiple input types together, the relationship between deployment flow, inference path, and system resources becomes much more important to observe. This makes multimodal workloads especially useful for edge AI evaluation, because they reflect platform feasibility under more realistic application conditions.
Using the Omni model as an example, developers can follow the corresponding Learning Path to deploy and validate a multimodal inference workflow on the CIX Armv9 platform. The goal is not simply to show that a modern model can be deployed and observed on Armv9. Instead, the focus is on building a reproducible multimodal workflow that developers can understand, repeat, and refine.
Through this Learning Path, developers do more than verify that a model runs successfully. They can gradually establish a practical deployment path, understand whether the workflow is stable, evaluate whether resource allocation is reasonable, and judge whether the flow is suitable for extension into real edge scenarios. In this context, multimodal inference becomes more than a feature demonstration. It becomes part of deployment evaluation itself.
The real meaning of optimization: moving from technical metrics to deployment decisions
In many technical discussions, optimization is often measured by throughput, latency, or execution speed. However, in edge AI, optimization is not simply about pushing numbers higher. It is about balancing platform capabilities, model requirements, and the needs of the target use case.
For developers, that distinction matters. In real projects, the question is often not “How do we maximize the benchmark?” but “How do we make the most suitable deployment choice under given platform constraints?” This includes assessing whether memory capacity is sufficient, whether the model size is appropriate, whether a workflow is too complex, or whether a specific model approach truly fits the intended use case.
That is why this article treats deployment, observation, and optimization as connected activities. Developers first need to deploy a model and observe how the system behaves. Those observations help identify meaningful optimization opportunities. At that point, optimization is no longer driven by benchmarks alone. It becomes part of making informed deployment decisions.
From this perspective, the value of the CIX Armv9 platform lies in supporting exactly this process. It offers more than the ability to run AI workloads. It provides an environment where developers can test ideas, rule out unsuitable options, and compare different deployment combinations. When that process is reproducible, developers can better understand the relationship between platform, model, and scenario, and to converge on an edge deployment strategy that is appropriate.
Why this matters to the global developer community
For the developer community, the value of these 2 Learning Paths extends beyond their individual technical content. Together they provide a practical path that can be understood, reused, and reproduced by developers globally.
Both Learning Paths are built on open-source toolchains and reproducible workflows. They are more than examples to read about. They are methods that developers can validate, compare, and extend for themselves. For the global developer community, that kind of reproducibility is important because it enables developers to repeat the work, verify the results, and build on them.
These Learning Paths also demonstrate that AI workloads emerging from China’s open-source model ecosystem can be deployed, observed, and optimized on a CIX Armv9 platform using open-source toolchains. The goal is to show the diversity of today’s model ecosystem and how different model approaches can be evaluated on a tangible platform.
For the global developer community, that value is clear. It becomes easier to compare model approaches, easier to place memory requirements and scenario fit into the same evaluation framework, and easier to move the discussion beyond model capability or hardware specs alone. This leads to more practical and actionable technical discussions.
For that reason, the CIX Armv9 platform is not the focus of the story. Instead, it provides a practical Armv9 platform that developers can use, helping make deployment assessment more concrete, more transparent, and more aligned with the realities of edge AI projects.
Conclusion: from model experimentation to edge deployment evaluation
Together, these 2 Learning Paths provide a practical approach to evaluating AI workloads on Armv9. Developers can start with open-source models and use open-source toolchains to build an evaluation method that is much closer to real deployment needs.
Through the cycle of deployment, observation, and optimization, developers can move beyond simply asking whether a model runs. They can understand model behaviors, establish reproducible workflows, and use real observations to assess trade-offs among memory capacity, model choice, and target use cases.
From this perspective, the value of the CIX Armv9 platform is not  as a conclusion itself. Instead, it  provides a practical Armv9 starting point that developers can use to experiment, validate, and compare. For developers bringing modern AI workloads closer to the edge, this helps connect model experimentation with deployment decisions. It also helps ensure deployment decisions are based on real application requirements.
If you would like to move beyond benchmarks and explore deployment, you can explore the deployment flows, observation methods, and implementation details discussed in this article, you can continue with the ERNIE 4.5 MoE Learning Path and the Omni multimodal Learning Path, and extend this path from model experimentation to edge deployment evaluation through hands-on practice.
