HomeCommunityAI blog
July 17, 2025
Empowering engineers with AI-enabled security code review
Metis uses AI to detect design flaws and logic bugs missed by traditional tools, helping teams build secure software with context-aware reviews.
By Michalis Spyrou
Reading time 7 minutes
AI is creating new ways to help teams build more secure software, complementing traditional tools by uncovering issues that go beyond rule-based detection. Design mistakes and logic flaws can hide in seemingly correct code. Their presence highlights why security code reviews are essential. Catching these issues early helps prevent them from becoming risks.
Traditional Static Application Security Testing (SAST) tools play a critical role in identifying well-known coding vulnerabilities at scale. They are fast, scale well across large code bases, and use rule-based pattern matching to catch common flaws during development.
However, certain types of security issues, like subtle logic flaws or design inconsistencies, aren’t always visible to such tools as it requires knowing how code is meant to behave. These issues need reasoning and context to understand, which is why engineers step in during code review.
Arm’s Product Security team has been exploring how large language models (LLMs) can assist in this part of the review process. The result is ‘Metis’, an AI-powered tool that complements SAST by adding reasoning and context.
Unlike rule-based tools, Metis does not analyze code in isolation. It uses source files and documentation to build a picture of how code is meant to behave. This means Metis can surface logic errors and design risks. Results are delivered with clear explanations, helping engineers quickly understand what’s wrong and why it matters.
Metis is now available on GitHub as an open source project.
In the rest of this blog post, we will review how Metis works, the architecture behind it, and learnings from internal tests.
Metis architecture
Metis is built on a retrieval-augmented generation (RAG) architecture. It combines LLMs with project-specific knowledge to deliver precise and contextual security insights.
When analyzing a project, Metis creates a custom knowledge base with relevant assets like source code, build files, and documentation. This gives the model a deep understanding of the system’s structure and intent.
Carefully designed prompts guide analysis, such as vulnerability detection, secure design assessment, or architectural consistency. The combination of a custom knowledge base and specialized prompts allows Metis to produce actionable results that support ultramodern secure development practices.
Metis supports C and C++ at launch and includes a plugin framework to add support for other programming languages and LLMs. It can analyze entire repositories, individual files, or targeted changes, like pull requests and recent edits, as part of the development workflow.
How Metis complements traditional tools
Static analysis tools are built around fixed rules, heuristics, and syntax-based pattern matching. This makes them excellent at identifying known vulnerabilities quickly and reliably, especially across large codebases.
These tools operate without an understanding of the system’s intent or architecture. They don’t see how components interact, why certain logic exists, or what the code is supposed to accomplish. That’s where Metis adds value.
Metis understands code in context
Metis complements SAST by embedding context and reasoning directly into the analysis process. It uses a knowledge base built from the actual code and documentation to understand what the system is meant to do, not just how it’s written.
This allows it to reason about logic and mirror how engineers approach code informed by architecture, purpose, and usage.
Metis reasons beyond patterns
Metis goes beyond surface-level matches by surfacing risks that fall outside of the scope of static rules. It can identify incorrect memory handling across function boundaries, pointer misuse, broken assumptions in control flow, and data dependencies.
Metis explains 'why'
Instead of returning rule violations, Metis explains its findings in clear summaries that explain the nature of a vulnerability and its implications. Developers don’t just see what’s wrong, but why it matters, helping them resolve issues faster.
Capability Traditional SAST Metis
Analysis Deterministic; pattern based and rule driven Non-deterministic; context aware
Code understanding Syntax level Semantic & architectural
False positives High due to lack of context Low due to contextual filtering
Vulnerability explanation Rule ID and short message Natural language explanation
Flexibility Custom rules per vulnerability type Prompting
Example of context-driven detection
In the following example, a loop attempts to remap memory addresses from one region to another. The code checks whether a value falls within a specific range, and if so, calculates a new address.
// Remap memory addresses from one region to another
for (uint32_t* ptr = start; ptr < end; ptr++) {
    uint32_t value = *ptr;
    if (value >= OLD_REGION_BASE && value < OLD_REGION_BASE + REGION_SIZE) {
        value = value - OLD_REGION_BASE + NEW_REGION_BASE;
The updated address is calculated but never written back to the original table. This means the remapping never actually happens. Because the code is structurally valid and doesn’t trigger any known SAST rules, traditional tools miss it.
Metis, however, recognized the intent of the loop and flagged the missing write as a logic flaw. By reasoning about expected behavior, not just syntax, it identified a genuine security-relevant issue that static tools missed.
File: src/memory/remap.c
Identified issue 1: Address Remapping Loop Does Not Update Memory
Snippet:
    if...
Why: In the remap_address_table function, the code is intended to adjust address references from an old memory region to a new one. However, the updated value stored in the local variable 'value' is never written back into memory at the pointer location (*ptr). This means the address entries remain unchanged, which can lead to unintended behavior if the system relies on those values being relocated correctly.
Mitigation: Update the loop so that after computing the new address, the value is written back. For example:
        value = ((value - OLD_REGION_BASE) + NEW_REGION_BASE);
        *ptr = value;
This ensures that each entry is properly updated to point to the relocated memory region.
Confidence: 1.0
This example highlights the kind of issue Metis is designed to catch, subtle logic errors that reflect a mismatch between what the code does and what it was meant to do. By grounding its analysis in context and intent, Metis surfaces risks that conventional tools often overlook.
Early results and impact
During internal trials across a range of C and C++ projects, Metis demonstrated strong potential as a security review assistant. It was evaluated on its ability to reason code, detect meaningful issues, and deliver insights that support secure development.
Key outcomes from these trials include:
  • Previously undetected vulnerabilities were found in pre-release firmware code and confirmed by engineering teams.
  • High-confidence findings, with a true positive rate of around 95%. Metis surfaced real, relevant issues in the majority of test cases, with only 5% missed entirely.
  • Surfaced long-standing issues that had gone unnoticed in existing codebases. For example, Metis flagged a logic flaw introduced in early 2024 that had persisted undetected until reviewed this year. In several cases, it highlighted risks that weren’t caught by traditional tools, especially in teams where static analysis was disabled or inconsistently used.
  • Accurate detection of known vulnerabilities, including real-world Common Vulnerabilities and Exposures (CVEs), even without prior tuning or exposure; highlighting the strength of the LLM’s reasoning capabilities.
  • Context-rich insights that reflect experienced reviewer reasoning, offering guidance on secure coding, raising design concerns, and prompting meaningful discussions during code review.
While Metis occasionally missed technical detail when project documentation was sparse, it consistently surfaced valuable insights. In some cases, it flagged code as suspicious with a generic explanation, helping steer engineers in the right direction. Missing detail also meant that, whilst real security issues were still identified, they weren’t explicitly labelled as such.
The results show that Metis can act as a context-aware, reasoning-driven reviewer, bridging the gap between conventional automation and expert human analysis.
Be part of the future development of Metis
Metis is just one step toward a broader opportunity; using generative AI to enhance how security is built into every stage of the development lifecycle.
Beyond code review, we see potential for tools like Metis to support secure design analysis, threat modeling, architecture validation, and other activities that have traditionally required deep manual expertise. By analyzing the actual codebase along with its documentation, structure, and intended behavior, Metis helps teams not just detect vulnerabilities; but build more secure systems by design.
We are sharing Metis with the community to accelerate progress in this space, and contributions are welcome. Developers can help by:
  • Adding support for new programming languages
  • Creating and testing new prompt templates
  • Experimenting with alternative LLMs
  • Improving and benchmarking RAG pipelines for different project types
We have already seen Metis uncover issues missed by conventional static tools, delivering results with a low false positive rate. While some setup is needed to integrate Metis into automated workflows, its lightweight design makes it easy to trial in existing review processes.
We are excited to continue exploring this space, and we invite you to try Metis on GitHub and share feedback, ideas, and improvements. Together, we can push the boundaries of what secure development looks like in the AI era.
1Log in to like this post
