File not found when executing assembled program
The main problemWhen assembling your first programs with AS, and linking it to external libraries like this :armv7a-hardfloat-linux-gnueabi-as -o test.o test.Sarmv7a-hardfloat-linux-gnueabi-ld.gold --hash-style=sysv -o test test.o -lc You might be co...
By Myy
The main problem
You might be confronted to this error when executing your program :
$ ./test
-bash: ./test: No such file or directory
Using strace to pinpoint the problem will result to something like this :
execve("./test", ["./test"], [/* 28 vars */]) = -1 ENOENT (No such file or directory)
write(2, "strace: exec: No such file or di"..., 40strace: exec: No such file or directory
) = 40
exit_group(1) = ?
+++ exited with 1 +++
Looking at execve manual page, ENOENT is described like this :
| ENOENT The file filename or a script or ELF interpreter does not exist, or a shared library needed for the file or interpreter cannot be found. |
The executable is not a script. The file clearly exists. However, the ELF interpreter ?
When running readelf -l elf_executable you can see which interpreter the executable tries to use. In this case, the output is :
Elf file type is EXEC (Executable file)
Entry point 0x81b8
There are 5 program headers, starting at offset 52
Program Headers:
Type Offset VirtAddr PhysAddr FileSiz MemSiz Flg Align
PHDR 0x000034 0x00008034 0x00008034 0x000a0 0x000a0 R 0x4
INTERP 0x0000d4 0x000080d4 0x000080d4 0x00013 0x00013 R 0x1
[Requesting program interpreter: /usr/lib/libc.so.1]
LOAD 0x000000 0x00008000 0x00008000 0x00208 0x00208 R E 0x1000
LOAD 0x000208 0x00009208 0x00009208 0x000cc 0x000cc RW 0x1000
DYNAMIC 0x000208 0x00009208 0x00009208 0x000a0 0x000a0 RW 0x4
Section to Segment mapping:
Segment Sections...
00
01 .interp
02 .interp .dynsym .dynstr .hash .gnu.version .gnu.version_r .rel.plt .plt .text
03 .dynamic .data .got
04 .dynamic
The line Requesting program interpreter shows which ELF interpreter the system tries to use. On this system /usr/lib/libc.so.1 does not exist, which is why executing the program returns "File not found".
However, on a Linux system for example, the standard ELF interpreter is not libc but ld.
The solution
Define the system dynamic linker as the ELF interpreter using the --dynamic-linker directive when linking the program.
When linking programs for Linux ARM systems :
armv7a-hardfloat-linux-gnueabi-ld.gold --hash-style=sysv --dynamic-linker=/lib/ld-linux-armhf.so.3 -o test test.o -lc
When linking programs for Android ARM systems :
armv7a-hardfloat-linux-gnueabi-ld.gold --hash-style=sysv --dynamic-linker=/system/bin/linker -o test test.o -lc
By Myy
