December 20, 2013
Virtualization on the Chromebook using KVM-tool
A lot has changed in a year, and progress stops for no man or woman. I documented last year how to get a standard Linux distribution running on the ARM powered Samsung Series 3 Chromebook, those steps also apply to the new HP 11 Chromebook. Thanks to...
By Andrew Wafaa
Reading time 8 minutes
A lot has changed in a year, and progress stops for no man or woman. I documented last year how to get a standard Linux distribution running on the ARM powered Samsung Series 3 Chromebook, those steps also apply to the new HP 11 Chromebook. Thanks to the Cortex-A15 based Exynos 5 Dual by Samsung Electronics 5250 at the heart of these devices, we have some additional ARMv7 extensions that enable hardware virtualization, so this time round I'm going to show you how to enable virtualization on your Chromebook, utilising the KVM hypervisor.
Now I'll be honest, this isn't actually something new. The fine folks at Virtual Open Systems have documented how to do this already. So why am I going to do the same? Well my steps will differ from Virtual Open Systems' by using the current stable Linux kernel (3.12.2 as of this post), and I will also be using KVM-tool to manage the virtual machines. KVM-tool is a lightweight tool that is suited to testing and development. It allows you to quickly bring up a virtual machine with very low overheads.
CAUTION
These steps will only work on the Samsung Series 3 Chromebook due to upstream not having support for the HP 11. Also you will lose WiFi functionality, so make sure you have a USB Ethernet adapter.
Host Kernel
Get the latest stable upstream kernel source:
git clone git://git.kernel.org/pub/scm/linux/kernel/git/stable/linux-stable.git
cd linux-stable
git checkout origin/linux-3.12.y -b linux-3.12.y
Apply the attached patches to fix an issue with DMA and also RTC (these patches should not be required after kernel 3.13.0):
git apply DMAfix.patch
git apply RTCfix.patch
Pull in the KVM-tool source:
git remote add kvm-tool git://github.com/penberg/linux-kvm.git
git remote update
git merge kvm-tool/master
Save the attached Chromebook.config file to PATH_TO_linux-stable/.config
Next step is to build the kernel. Make sure you have a recent cross-compiler, Linaro provide a build of GCC 4.8:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- uImage dtbs
Copy the resulting binaries to a safe location for future use. The binaries are located at linux-stable/arch/arm/boot/uImage and linux-stable/arch/arm/boot/dts/exynos5250-snow.dtb
Guest Kernel
For the virtual machine guests, we will use the same kernel source as that running on the Chromebook host. As KVM tool provides a para-virtualised environment, so the guest operating system requires some .config options to be enabled in order to make use of any virtual devices. Here are the options required and an explanation of those options:
OptionDescriptionRequired by
VIRTIO=ySupport for the virtio busAll virtio-based devices
VIRTIO_BALLOON=ySupport for virtio-based memory deviceBalloon functionality on the host, allows control of guest memory pressure
VIRTIO_BLK=ySupport for a virtio-based block deviceGuest block device operations, e.g. booting a filesystem image
VIRTIO_CONSOLE=ySupport for a virtio-based consoleGuest console output
VIRTIO_MMIO=ySupport for MMIO devices on a virtio busAll MMIO virtio-based devices (i.e. all devices for ARM)
VIRTIO_NET=yVirtual network interfaceGuest network operations, e.g. NFS filesystem
NET_9P_VIRTIO=y, 9P_FS=y9pfs virtio transport9pfs mounts using a virtio pdu, can be used to mount the host filesystem
CONFIG_SERIAL_OF_PLATFORM=ydevice-tree serial consoleIf you want to use serial8250 instead of virtio console
The guest must also have support for mach-virt or also known as the "linux,dummy-virt" machine, which is the virtual platform targeted by kvm tool.
The attached guest.config file has all the necessary config options enabled, just download it and save it to PATH_TO/linux-stable/.config
Then build the kernel:
make ARCH=arm CROSS_COMPILE=arm-linux-gnueabihf- all
KVM-tool
Build KVM-tool:
cd tools/kvm
The result is the lkvm binary.
Again, copy the zImage to a safe place for future usage.
Bootloader
To enable access to the virtualization extensions, we need to boot the Chromebook into what is known as Hyp Mode (more information on Hyp Mode can be found at Chapter 27 of the Cortex-A Series Programmer’s Guide.  To be able to enter Hyp Mode, we need to use a secondary bootloader as the Chromebook’s bootloader doesn’t support entering this higher privileged run level.
To do this we will build a version of u-boot. Rather than use upstream’s u-boot source tree, we will use Virtual Open Systems’ tree as they have integrated many of the fixes needed to fully support Hyp mode, and also have an easy to use script for building u-boot.
git clone git://github.com/virtualopensystems/u-boot.git
cd u-boot
./scripts/build.sh
Userland
Get your target root filesystem. Make sure that your target Distribution is built for Hard Float.
Obtain a target SD Card (I am using a 32GB class 10 micro-SD card with adapter)
Now that the pre-requisites are completed, it's time to move onto preparing the target SD card. Insert the card into your desktop/laptop and note the device id, running 'dmesg' from a terminal after inserting the card will show you something along the lines of
'sd 6:0:0:0: [sdX] Attached SCSI removable disk'
Depending on your SD card reader it could also show up as mmcblk0. Replace 'sdX' with the correct id for your card. Ensure the target card is un-mounted and not ejected.
Virtual Open Systems supply a simple and friendly script that takes care of the numerous steps needed to get a working SD card, it is in the u-boot tree that we chacked out. It is always good practise to verify scripts before executing them, so by all means do have a look at it before running the command below.
cd PATH_TO/u-boot
sudo ./scripts/sdcard.sh /dev/sdX
The script creates 4 partitions:
  • sdX1 – for a signed u-boot (the script signs it for you)
  • sdX2 – is unused, you could place the original 3.4 based kernel here if you wish (you will need to sign it)
  • sdX3 – an ext2 partition for the kernel uImage and device tree blob used by u-boot
  • sdX4 – an ext4 partition for your filesystem
Now that we have the target card almost ready we need to extract our filesystem to the root partition. Mount the correct partition somewhere (in this case we are using '
/mnt')
sudo mount /dev/sdX4 /mnt
cd /mnt
Replace the path to the root filesystem below with the correct one for your choice
sudo tar xvpf ~/Downloads/target_rootfs.tar.bz2
sudo umount /dev/sdX4
Copy the supporting files for u-boot
sudo mount /dev/sdX3 /mnt
sudo cp /PATH_TO_BINARY/uImage /mnt
sudo cp /PATH_TO_BINARY/exynos5250-snow.dtb /mnt
sudo umount /dev/sdb3
KVM-tool
Copy the kvm-tool binary
sudo cp PATH_TO/linux-stable/tools/kvm/lkvm /mnt/usr/bin
Copy the guest kernel to the SD card
sudo cp PATH_TO_GUEST/zImage /mnt/home
sudo umount /dev/sdX3
Booting the host and using KVM-tool
Once you have completed the above steps, you are now ready to boot your Chromebook, just insert the SD card and boot. At the boot verification screen press Ctrl+U and it will boot from the SD card. Don’t be alarmed when you see a screen with timer information, give it a minute or two to settle down and it will then boot into Linux.
Once you have logged in you can run KVM-tool by opening up a terminal and running:
lkvm run /home/zImage --balloon --network trans=mmio,mode=user --console virtio –c 2 –m 1024 -p “console=hvc0,38400”
This will boot your VM with 2 CPUs (-c 2), 1 GB of memory (-m 1024), a network interface and memory ballooning.
As we are not specifying a disk image, lkvm will automatically mount the host file-system at /host using 9pfs. This provides an easy way to transfer files between guest and host.
See how much memory is available from within the guest:
$ free              total      used      free shared    buffers    cached Mem:      1035068      42388 992680          0      1764 10900 -/+ buffers/cache: 29724    1005344 Swap:            0          0          0
Now, we can steal 256M from the guest by executing the following on the host:
$ lkvm list    PID NAME                STATE ------------------------------------ 8180 guest-8180 running      default              shut off $ ./lkvm balloon -n guest-8180 -i 256
Then, back on the guest:
$ free              total      used      free shared    buffers    cached Mem:        772924      42220 730704          0      1764 10912 -/+ buffers/cache:      29544    743380 Swap:            0          0          0
2Log in to like this post
