Embedded C Programming with Arm Cortex-M Video Course
The course starts from the beginning and is structured as a series of short, focused, hands-on lessons that teach you how to program Arm Cortex-M microcontrollers in C.
By Miro Samek
I believe that the Arm Community could be interested in the "Embedded C Programming Course with Arm Cortex-M" video course, which I've been teaching for over a year on YouTube. The playlist for this course is available below.
Embedded Systems Programming Course on YouTube
My goal is not just to teach C–other courses do it already quite well. But there are virtually no courses that would step down to the machine level and show you exactly what happens inside the Arm processor. This deeper understanding will allow you to use both the Arm processor and the C language more efficiently and with greater confidence. You will gain understanding not just what for your program does, but also how the C statements translate to machine instructions and how fast the processor can execute them.
What I believe is special about this "Modern Embedded Programming" course is that it shows exactly what happens inside an Arm Cortex-M microcontroller. Specifically, I use the IDE and the various views in the debugger, such as disassembly, registers, memory, variables, call stack, etc. to explain exactly what's happening and also what can go wrong. For example, in the lesson about functions and the stack, I show an example of a stack overflow. (Have you ever seen how an Arm CPU "executes" it's own interrupt table?) In the lesson about stdint.h and mixing integers in expressions I show examples of non-portable code and how it changes behavior between 32-Arm and 16-bit MSP430. In the last lesson about structures I show how Cortex-M3/M4 can handle misaligned data while Cortex-M0 can't, and so on.
Here is the list of the lessons released so far:
- Lesson 0 ( 9:17): Getting Started
- Lesson 1 (17:06): Counting
- Lesson 2 (11:00): Flow of Control
- Lesson 3 (12:23): Variables and Pointers
- Lesson 4 (16:45): Blinking the LED
- Lesson 5 (14:30): Preprocessor and volatile
- Lesson 6 (17:06): Bit-wise operators in C
- Lesson 7 (15:22): Arrays and Pointer Arithmetic
- Lesson 8 (17:06): Functions and the Stack
- Lesson 9 (19:08): Modules, Recursion, AAPCS
- Lesson 10 (27:42): Stack Overflow and Other Pitfalls of Functions
- Lesson 11 (28:34): <stdint.h>, Endianness, Mixing Types in Expressions
- Lesson 12 (32:11): Structures and CMSIS
I’d love to hear your comments about the course. Is there anything that you would like to see in the upcoming lessons? Do you see anything that you would teach differently? Or perhaps you have ideas for teaching specific subjects? Please share…
By Miro Samek
