July 6, 2016
IoT Security: Creating X.509 Chain of Trust
Learn the entire process of setting up the chain of trust for your IoT solution. The video, which is available on YouTube, provides a practical example that you can follow and setup on your own computer for learning purposes. The comprehensive video ...
By Wilfred Nilsen
Reading time less than 1 minute
Learn the entire process of setting up the chain of trust for your IoT solution. The video, which is available on YouTube, provides a practical example that you can follow and setup on your own computer for learning purposes. The comprehensive video tutorial guides you through the process of setting up secure and trusted communication. After completing the hands-on tutorials, you will be an expert in using SSL for secure communication and how to create and manage SSL certificates.
The video shows how to create an Elliptic Curve Cryptography (ECC) certificate for the server, how to install the certificate in the server, and how to make the clients connecting to the server trust this certificate. The server in this video is installed on a private/personal computer on a private network for test purposes.
1Log in to like this post
