October 29, 2013
ARM Mali-T720 Overview
The ARM® Mali™-T720 GPU is the first offering in the Mid-Range GPU series which has its origins in the Midgard Architecture. It is an extremely area-efficient GPU designed specifically to bring high quality, energy efficient GPU Compute gr...
By Ellie Stone
Reading time 2 minutes
The ARM® Mali™-T720 GPU is the first offering in the Mid-Range GPU series which has its origins in the Midgard Architecture. It is an extremely area-efficient GPU designed specifically to bring high quality, energy efficient GPU Compute graphics features to the low-to mid- range Android™ mobile market. With a reduced die-area and simplified layout compared to the ARM Mali-T600 series, the ARM Mali-T720 GPU proposes a significantly decreased time to market without compromising on graphical performance.
Why Mali-T720?
The ARM Mali-T720 is a cost-optimized version of the ARM Mali-T600 family of GPUs designed to bring GPU Compute functionality to low- to mid-range Android smartphones, tablets and DTVs. The ARM Mali-T720 GPU increases energy efficiency by 150% and graphics performance by more than 50% over previous Mali cost-optimized, mid-range graphics processors.
Advancements to the Midgard family’s routing density, top-level layout and layering have significantly reduced the ARM Mali-T720 GPU’s die-area, implementation effort and cost, making it the ideal GPU for the fast-moving entry-level smartphone market where low-cost and time to market are essential for success.  Targeted specifically at the Android market, the ARM Mali-T720 GPU simplifies implementation effort even further by offeringoptimized API support* for OpenGL® ES 3.0/2.0/1.0 and RenderScript.
It maintains compatibility with software development assets of the Midgard architecture including the trusted and stable ARM Mali GPU DDK, which is provided under the standard ARM commercial licence to all ARM Mali GPU customers.
ARM POP™ IP for the Mali-T720 will be made available to further decrease time to market and improve the dependability of your product. ARM POP IP is core-hardening acceleration technology for producing the best ARM processor implementations in the fastest time to market with the flexibility to optimize for maximum performance, lowest power, or any combination in between.
*Product is based on a published Khronos Specification, and is expected to pass the Khronos Conformance Testing Process. Current conformance status can be found at www.khronos.org/conformance
Performance
For ARM Mali-T720 MP8
Feature
ValueDescription
Frequency   695MHzin 28nm HPM
Throughput   695Mtri/s, 5.6Gpix/s  in 28nm HPM
3Log in to like this post
