Debugging OpenCL Applications with Mali Graphics Debugger V2.1 and GPUVerify
Most people use Mali Graphics Debugger (MGD) to help debug OpenGL® ES applications on Linux or Android. However graphics is not the only API that is supported by MGD, in-fact MGD supports applications that use the OpenCL™ API as well. This...
Most people use Mali Graphics Debugger (MGD) to help debug OpenGL® ES applications on Linux or Android. However graphics is not the only API that is supported by MGD, in-fact MGD supports applications that use the OpenCL™ API as well. This means that if you run MGD with an application that uses OpenCL you will get the same function level tracing that you would get with OpenGL ES. You will also get access to the kernel source code in much the same way you would get access to your OpenGL ES shader source code.
With the release 2.1 of Mali Graphics Debugger the OpenCL feature set has been improved by the inclusion of GPUVerify support. GPUVerify is a tool for formal analysis of kernels written in OpenCL and was partly funded by the EU FP7 CARP project http://carpproject.eu/. The tool can prove that kernels don’t suffer from the following three issues:
- Intra-group data races: This is when there is a data race between work items in the same work group.
- Inter-group data races: This is when there is a data race between work items in different work groups.
- Barrier divergence: This is when a kernel breaks the rules for barrier synchronization in conditional code defined in the OpenCL documentation.
The tool was created by Imperial College London and more information about the tool and the issues it can diagnose can be found by visiting http://multicore.doc.ic.ac.uk/GPUVerify.
In essence if you provide GPUVerify with the source code of a OpenCL kernel along with the local and global work group sizes it can check your kernel for the issues highlighted above. One of the main reasons for including support for this tool in MGD is that the information required to run GPUVerify is already known from tracing your application. The steps needed to use this tool with MGD are outlined below:
Step 1: Download Mali Graphics Debugger v2.1 and GPUVerify
Mali Graphics Debugger can be downloaded from http://malideveloper.arm.com/develop-for-mali/tools/software-tools/mali-graphics-debugger/. If you are using an older version of MGD you will need to upgrade. Version 2.1 has much more included than just GPUVerify support, a few items are listed below:
- Support for ARMv8 (Android 64-bit)
- Support for tracing Android Extension Pack
- Many improvements to the Frame Overrides feature.
GPUVerify can be downloaded in binary form for both Linux and Windows from the following location: http://multicore.doc.ic.ac.uk/tools/GPUVerify/download.php. GPUVerify does support Mac OS X as well but you will have to build it from source.
Step 2: Make sure GPUVerify is working stand-alone
Using GPUVerify successfully inside MGD is often easier once it is established that GPUVerify works in a stand-alone capacity. Once it has been downloaded the process of making it work is easy thanks to the documentation provided on the GPUVerify's website. Along with a section that provides common troubleshooting advice. A good way to check that it is working correctly is to try GPUVerify with some of the examples that are provided with the Mali OpenCL SDK.
The following image is of the output from GPUVerify running the HelloWorld example from the Mali OpenCL SDK:
Step 3: Making MGD Aware of the Location of GPUVerify
As GPUVerify is not shipped with MGD you must specify the location of where you installed it to MGD. To do this in MGD do the following:
- Click Edit -> Preferences
- Click on the Text box next to "Path to GPUVerify" and provide the location of the GPUVerify binary.
Step 4: Run a normal OpenCL trace in MGD
As mentioned previously MGD will try to fill in the prerequisite information for GPUVerify from the trace. It does this by looking for several functions; the most important are clCreateProgramWithSource, clCreateKernel and clEnqueueMapBuffer.
If you don't use clCreateKernel to create your kernels, MGD can also obtain the information from clCreateKernelsInProgram. As shown in the image above MGD also captures the build options used in clBuildProgram to pass to GPUVerify. The more details that can be passed to GPUVerify the more accurate it can analyze your kernels.
Step 5: Running GPUVerify from MGD
To run the tool you need to select Debug -> Launch GPU Verify. MGD will then present a new dialog box which summarizes all of the information MGD managed to pull out of the trace. You are free to fill this information in or even change the information. One of the reasons you may want to do this is to try new work group sizes or global work sizes, to see if there are any unforeseen issues with different kernel parameters.
Stage 6: Analyzing the Results
The results should be placed in the console view as part of MGD. Here are the results of the HelloWorld example from above running through MGD:
Mali Graphics Debugger can be used to do much more than debug and trace graphics applications. It can be used to debug and trace OpenCL applications as well. With the inclusion of GPUVerify support it is now possible to debug possible data race conditions in your kernels as well as barrier divergence issues. MGD will send as much data as it can to GPUVerify by analyzing the trace of your OpenCL application.
