How to compile a 4.9 kernel with Mali r15p0 kernel drivers for a MiQi device ( RK3288 )
Until I get a recent Mali User-Space drivers build from Rockchip or the Rockchip Mali User-space drivers DDK, here's how to compile an official (read Linus Torvalds git branch) 4.9 kernel, with the official Mali r15p0 Kernel drivers, in order to use ...
By Myy
Until I get a recent Mali User-Space drivers build from Rockchip or the Rockchip Mali User-space drivers DDK, here's how to compile an official (read Linus Torvalds git branch) 4.9 kernel, with the official Mali r15p0 Kernel drivers, in order to use it on a MiQi device ( RK3288 board ) with the Mali r12p0 User-Space drivers for Firefly boards.
You can also find this procedure and a pre-compiled kernel on my Github repository.
This procedure does not enable the UMP drivers however...
The procedure
# Get the kernel export KERNEL_VERSION=v4.9 git clone --depth 1 --branch $KERNEL_VERSION 'git://git.kernel.org/pub/scm/linux/kernel/git/torvalds/linux.git' && cd linux # Download, prepare and copy the Mali Kernel-Space drivers. # Some TGZ are AWFULLY packaged with everything having 0777 rights. export MALI_VERSION=r15p0-00rel0 wget "http://malideveloper.arm.com/downloads/drivers/TX011/$MALI_VERSION/TX011-SW-99002-$MALI_VERSION.tgz" && tar zxvf TX011-SW-99002-$MALI_VERSION.tgz && cd TX011-SW-99002-$MALI_VERSION && find . -type 'f' -exec chmod 0644 {} ';' && find . -type 'd' -exec chmod 0755 {} ';' && find . -name 'sconscript' -exec rm {} ';' && rm -r 'driver/product/kernel/patches' 'driver/product/kernel/license.txt' && cp -r driver/product/kernel/drivers/gpu/arm ../drivers/gpu/ && cp -r driver/product/kernel/drivers/base/ump ../drivers/base/ && cd .. && rm -r TX011-SW-99002-$MALI_VERSION TX011-SW-99002-$MALI_VERSION.tgz # Apply the Rockchip DRM, Rockchip fbdev, RK3288 DTS and # Kconfig/Makefile patches used to enable the compilation of the # Mali driver export GITHUB_REPO=Miouyouyou/MyyQi export GIT_BRANCH=master export PATCHES_FOLDER_URL=https://raw.githubusercontent.com/$GITHUB_REPO/$GIT_BRANCH/patches export KERNEL_PATCHES_FOLDER_URL=$PATCHES_FOLDER_URL/kernel/$KERNEL_VERSION wget $KERNEL_PATCHES_FOLDER_URL/0001-Rockchip-DRM-and-Framebuffer-patches-from-ARM-softwa.patch && wget $KERNEL_PATCHES_FOLDER_URL/0002-Integrate-the-Mali-GPU-address-to-the-rk3288-and-rk3.patch && wget $KERNEL_PATCHES_FOLDER_URL/0003-Post-Mali-Kernel-device-drivers-modifications.patch export PATCHES="0001-Rockchip-DRM-and-Framebuffer-patches-from-ARM-softwa.patch 0002-Integrate-the-Mali-GPU-address-to-the-rk3288-and-rk3.patch 0003-Post-Mali-Kernel-device-drivers-modifications.patch" git apply $PATCHES && rm $PATCHES unset PATCHES # Apply a patch to the Mali Midgard driver that adapt the # get_user_pages calls to the new signature. export MALI_PATCHES_FOLDER=$PATCHES_FOLDER_URL/Mali/$MALI_VERSION wget $MALI_PATCHES_FOLDER/0001-Adapt-get_user_pages-calls-to-use-the-new-calling-pr.patch && git apply 0001-Adapt-get_user_pages-calls-to-use-the-new-calling-pr.patch && rm 0001-Adapt-get_user_pages-calls-to-use-the-new-calling-pr.patch # Get the configuration file and compile the kernel export ARCH=arm
# Uncomment the following if you're cross-compiling ! #export CROSS_COMPILE=armv7a-hardfloat-linux-gnueabi- make mrproper wget -O .config 'https://raw.githubusercontent.com/Miouyouyou/MyyQi/master/boot/config-4.9.0MyyMyy%2B' make rk3288-miqi.dtb zImage modules -j5
Testing
The compiled kernel was tested successfully with the r12p0 Mali User-Space fbdev and Wayland drivers for Firefly boards, using the Mali OpenGL SDK samples for fbdev tests and Mesa demos for Wayland tests.
The test methodology boiled down to:
# FBDEV. Require to download the Mali OpenGL ES SDK. cp /path/to/Mali_OpenGL_ES_SDK_v2.4.4.71fdbd_Linux_x86.tar.gz /tmp tar zxvf Mali_OpenGL_ES_SDK_v2.4.4.71fdbd_Linux_x86.tar.gz cd Mali_OpenGL_ES_SDK_v2.4.4 TARGET="arm" TOOLCHAIN_ROOT="" cmake . make -j5 export LD_LIBRARY_PATH=/path/where/mali-fbdev-drivers-are/fbdev cd samples/opengl_31/compute_particles/ ./compute_particles # Wayland cd /tmp git clone git://cgit.freedesktop.org/mesa/demos --depth 1 cd demos ./autogen.sh --enable-wayland --enable-gles2 export LD_LIBRARY_PATH=/path/to/mali-wayland-folder weston # Inside the weston terminal export LD_LIBRARY_PATH=/path/to/mali-wayland-folder cd /tmp/demos/src/egl/opengles2 ./es2gears_wayland
Patches
I've attached the patch applied on the Mali Kernel r15p0 drivers sources.
By Myy
