Mali Performance 6: Efficiently Updating Dynamic Resources
My last blog looked at some of the critical areas which an application has to implement efficiently to get best performance out of 3D content, such as broad-brush culling of large sections of a scene which are guaranteed not to be visible so they ar...
By Peter Harris
My last blog looked at some of the critical areas which an application has to implement efficiently to get best performance out of 3D content, such as broad-brush culling of large sections of a scene which are guaranteed not to be visible so they are not sent to the GPU at all. In one of the follow on comments to this blog seanlumly01 asked "Is there a performance penalty for an application modifying textures between draw calls?". It is a really good question, but the answer is non-trivial, so I deferred to this blog post to answer it fully.
Pipelined Rendering
The most important thing to remember when it comes to resource management is the fact that OpenGL ES implementations are nearly all heavily pipelined. This is discussed in more detail in this earlier blog, but in summary ...
When you call glDraw...() to draw something the draw does not happen instantly, instead the command which tells the GPU how to perform that draw is added to a queue of operations to be performed at some point in future. Similarly, eglSwapBuffers() does not actually swap the front and back buffer of the screen, but really just tells the graphics stack that the application has finished composing a frame of rendering and queues that frame for rendering. In both cases the logical specification of the behaviour - the API calls - and the actual processing of the work on the GPU are decoupled by a buffering process which can be tens of milliseconds in length.
Resource Dependencies
For the most part, OpenGL ES defines a synchronous programming model. Apart from a few explicit exceptions, when you make a draw call rendering must appear to have happened at the point that the draw call was made, with pixels on screen correctly reflecting the state of any command flags, textures, or buffers at that point in time (based either on API function calls or previously specified GPU commands). This appearance of synchronous rendering is an elaborate illusion maintained by the driver stack underneath the API, which works well but does place some constraints on the application behavior if you want to achieve the best performance and lowest CPU overheads.
Due to the pipelining process outlined earlier, enforcing this illusion of synchronicity means that a pending draw call which reads a texture or buffer effectively places a modification lock on that resource until that draw operation has actually completed rendering on the GPU.
For example, if we had a code sequence:
glBindTexture(1) // Bind texture 1, version 1 glDrawElements(...) // Draw reading texture 1, version 1 glTexSubImage2D(...) // Modify texture 1, so it becomes version 2 glDrawElements(...) // Draw reading the texture 1, version 2
... then we cannot allow the glTexSubImage2D() to modify the texture memory until the first draw call has actually been processed by the GPU, otherwise the rendering of the first draw call will not correctly reflect the state of the GL at the point the API call was made (we need it to render the draw using the contents of the physical memory which reflect texture version 1, not version 2). A lot of what OpenGL ES drivers spend their time doing is tracking resource dependencies such as this one to make sure that the synchronous programming "illusion" is maintained, ensuring that operations do not happen too early (before the resources are available) or too late (after a later resource modification has been made).
Breaking Resource Dependencies
In scenarios where a resource dependency conflict occurs - for example a buffer write is requested when that buffer still has a pending read lock - the Mali drivers cannot apply the resource modification immediately without some special handling; here are multiple possible routes open to the drivers to resolve the conflict automatically.
Pipeline Finish
We could drain the rendering pipeline to the point where all pending reads and writes from the GPU for the conflicted resource are resolved. After the finish has completed we can process the modification of the resource as normal. If this happens part way through the drawing of a framebuffer you will incur incremental rendering costs where we are forced to flush the intermediate render state to main memory; see this blog for more details.
Draining the pipeline completely means that the GPU will then go idle waiting for the CPU to build the next workload, which is a poor use of hardware cycles, so this tends to be a poor solution in practice.
Resource Ghosting
We can maintain both the illusion of the synchronous programming model and process the application update immediately, if we are willing to spend a bit more memory. Rather than modifying the physical contents of the current resource memory, we can simply create a new version of the logical texture resource, assembling the new version from both the application update and any of the data from the original buffer (if the modification is only a partial buffer or texture replacement). The latest version of the resource is used for any operations at the API level, older versions are only needed until their pending rendering operations are resolved, at which point their memory can be freed. This approach is known as resource ghosting, or copy-on-write.
This is the most common approach taken by drivers as it leaves the pipeline intact and ensures that the GPU hardware stays busy. The downsides of this approach are additional memory footprint while the ghost resources are alive, and some additional processing load to allocate and assemble the new resource versions in memory.
It should also be noted that resource ghosting isn't always possible; in particular when resources are imported from external sources using a memory sharing API such as UMP, Gralloc, dma_buf, etc. In these cases other drivers, such as cameras, video decoders, and image processors may be writing into these buffers and the Mali drivers have no way to know whether this is happening or not. In these cases we generally cannot apply copy-on-write mechanisms, so the driver tends to block and wait for pending dependencies to resolve. For most applications you don't have to worry about this, but if you are working with buffers sourced from other media accelerators this is one to watch out for.
Application Overrides
Given that resource dependencies are a problem on all hardware rendering systems due to pipeline depth, it should come as no surprise that more recent versions of OpenGL ES come with some features which allow application developers to override the purely synchronous rendering illusion to get more fine control if it is needed.
The function glMapBufferRange() function in OpenGL ES 3.0 allows application developers to map a buffer into the application's CPU address space. Mapping buffers allows the application to specify an access flag of GL_MAP_UNSYNCHRONIZED_BIT, which loosely translates as the "don't worry about resource dependencies, I know what I am doing" bit. When a buffer mapping is unsynchronized the driver does not attempt to enforce the synchronous rendering illusion, and the application can modify areas of the buffer which are still referenced by pending rendering operations and therefore cause incorrect rendering for those operations if the buffer updates are made erroneously.
Working With Resource Dependencies
In addition to the direct use of features such as GL_MAP_UNSYCHRONIZED_BIT, many applications work with the knowledge that the resource usage is pipelined to create flexible rendering without causing excessive ghosting overheads.
Separate Out Volatile Resources
Ghosting can be made less expensive by ensuring that volatile resources are separated out from the static resources, making the memory regions which need to be allocated and copied as small as possible. For example, ensuring that animated glyphs which are updated using glTexSubImage2D() are not sharing a texture atlas with static images which are never changed, or ensuring that models which are animated in software on the CPU (either via attribute or index update) are not in the same buffer as static models.
Batch Updates
The overheads related to buffer updates can be reduced, and the number of ghosted copies minimized, by performing most of the resource updates in a single block (either one large update or multiple sequential sub-buffer/texture updates), ideally before any rendering to a FBO has occurred. Avoid interleaving resource updates with draw calls like this ...
glBufferSubData glDraw glBufferSubData glDraw glBufferSubData glDraw
... unless you are able to use GL_MAP_UNSYNCHORNIZED_BIT. It is usually much more efficient to make the same set of updates like this:
glBufferSubData glBufferSubData glBufferSubData glDraw glDraw glDraw
Application Pipelined Resources
If the application wants to make performance more predictable and avoid the overheads of ghosting reallocating memory in the driver, one technique it can apply is to explicitly create multiple copies of each volatile resource in the application, one for each frame of latency present in the rendering pipeline (typically 3 for a system such as Android). The resources are used in a round-robin sequence, so when the next modification of a resource occurs the pending rendering using that resource should have completed. This means that the application modifications can be committed directly to physical memory without needing special handling in the driver.
There is no easy way to determine the pipeline length of an application, but it can be empirically tested on a device by inserting a fence object by calling glFenceSync() after a draw call using a texture, and then polling that fence object by calling glClientWaitSync() with a timeout of zero just before making the modifications N frames later. If this wait returns GL_TIMEOUT_EXPIRED then the rendering is still pending and you need to add an additional resource version to the resource pool you are using.
Thanks to Sean for the good question, and I hope this answers it!
Cheers,
Pete
Next Blog In Series: Mali Performance 7: Accelerating 2D rendering using OpenGL ES
Pete Harris is the lead performance engineer for the Mali OpenGL ES driver team at ARM. He enjoys spending his time working on a whiteboard and determining how to get the best out of combined hardware and software compute sub-systems. He spends his working days thinking about how to make the ARM Mali GPUs even better.
By Peter Harris
