June 4, 2016
[Quick tips] Use ffmpeg to convert pictures to raw RGB565
Here's a quick tip to convert pictures to raw format with FFMPEG, in order to use them as a texture in OpenGL, with no extra conversion :BMP filesffmpeg -vcodec bmp -i /path/to/texture-file.bmp -vcodec rawvideo -f rawvideo -pix_fmt rgb565 texture...
By Myy
Reading time less than 1 minute
BMP files
ffmpeg -vcodec bmp -i /path/to/texture-file.bmp -vcodec rawvideo -f rawvideo -pix_fmt rgb565 texture.raw
PNG files
ffmpeg -vcodec png -i /path/to/texture-file.png -vcodec rawvideo -f rawvideo -pix_fmt rgb565 texture.raw
Loading a raw format picture as a texture in OpenGL
int fd = open("texture.raw", O_RDONLY);
read(fd, texture_buffer, raw_picture_file_size_in_bytes);
close(fd);
glTexImage2D(GL_TEXTURE_2D, 0, GL_RGB, picture_width, picture_height, 0, GL_RGB, GL_UNSIGNED_SHORT_5_6_5, texture_buffer);
glGenerateMipmap(GL_TEXTURE_2D);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_S, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_WRAP_T, GL_REPEAT);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MAG_FILTER, GL_NEAREST);
glTexParameteri(GL_TEXTURE_2D, GL_TEXTURE_MIN_FILTER, GL_NEAREST_MIPMAP_NEAREST);
The biggest advantage is that FFMPEG will implicitly flip the picture upside-down during the conversion, meaning that the upper-left of your original texture is at UV coordinates 0.0,0.0 instead of 1.0,0.0.
Got this quick tip from BMPとRAWデータ(RGB8888/RGB565)の相互変換メモ - Qiita
Myy's profile picture
By Myy
