Empowering creators: How stdio x labs cut event analytics latency by 40% using Arm-accelerated BigQuery ML on Google Cloud
Migrating to Arm on Google Cloud helped SoldOutAfrica improve performance, reduce costs, and increase event revenue
The moment our data dreams hit scalability reality
SoldOutAfrica, built by our startup stdio x labs, is more than a ticketing platform. Its mission is to give artists and organizers unprecedented control and data-driven intelligence over their events. We empower creators to manage ticketing, enhance audience engagement, and leverage powerful analytics to drive success.
Our core value proposition is delivering real-time, actionable insights such as predicting ticket sell-out velocity or recommending VIP upsells to organizers while the event is still on sale.
We initially built our platform on a standard Google Cloud architecture using General Purpose x86 (n2-standard-4) instances and a basic Cloud SQL database. This setup handled our early ticketing volumes. However, our ambition to use real-time data to drive predictive analytics exposed a critical bottleneck.
- The bottleneck: We were ingesting large, fluctuating streams of real-time event data like ticket scans, website clicks, and app interactions through Cloud Pub. Our x86-based data pipelines processed this high-volume and high-velocity data stream with high latency. This delay affected the complex BigQuery ML that generate predictive insights.
- The cost: Running memory and CPU-intensive Python stream processing on x86 Compute Engine instances for hours every day led to increasing compute costs. These costs threatened our unit economics as we scaled.
When a large festival organizer reported that their predictive dashboard was lagging by over 30 minutes during a peak sale, we faced a hard truth: Brilliant data is useless if it is not fast enough to act upon.
Why event economics demands real-time edge intelligence
The event industry often depends on immediate decisions. An organizer must know immediately if a ticket tier is underselling so they can launch an immediate marketing campaign. They must also know if a high-traffic source has low conversion so they can adjust ad spend. This requires:
- Massive data ingestion: Handle millions of real-time events such as scans, clicks, and purchases, per hour during peak on-sale periods.
- Predictive accuracy: Run complex machine learning models like XGBoost, or forecasting models over massive datasets for highly accurate predictions.
- Low latency output: Serve predictions to the organizer dashboard in less than one minute for immediate action.
Traditional data warehousing and processing, often struggle with this combination of volume, velocity, and complexity. We needed an architectural edge.
The stdio x labs solution: Arm-accelerated data processing on Google Cloud
We decided to migrate our entire stream processing and complex ML pre-processing layer to Arm Neoverse-based Compute Engine Tau T2A instances on Google Cloud. We selected Arm to improve the performance-per-watt advantage in our most intensive, always-on data pipelines.
Our migration strategy involved four critical components:
| Component | Google Cloud Service | Arm Optimization | Outcome |
| Data Ingestion | Cloud Pub/Sub | N/A (Serverless) | Reliable, high-throughput ingestion of real-time ticket events. |
| Stream Processing | Compute Engine (Tau T2A) / Dataflow | Migrated data-heavy Python/Java pipelines to Arm64 Tau T2A VMs for superior price-performance. | Reduced compute cost and faster data transformation before ML. |
| Predictive Modeling | BigQuery ML | Used BigQuery's underlying infrastructure efficiency, fed by faster Arm-processed data. | Enabled sub-minute model retraining/inference. |
| Analytics Visualization | Looker Studio | Visualization Layer | Real-time dashboards reflecting the low-latency BigQuery output. |
The technical transformation journey
Phase 1: Migrating Python workers to Arm-native Tau T2A
Our first challenge was identifying and migrating the most CPU-intensive parts of our data pipeline. These included feature engineering and cleaning large pandas and numpy datasets before loading them into BigQuery.
We created a custom Compute Engine instance template using the Arm-based Tau T2A series. We containerized our Python worker applications using a minimal Arm64 base image, Alpine-Arm64. We deployed them on Google Kubernetes Engine (GKE) nodes running on Tau T2A.
The immediate benefit is native execution for our data workers, which removes the performance overhead of cross-architecture virtualization. We saw an immediate gain in I/O and processing speed for our stream analytics tasks.
Phase 2: Optimizing the BigQuery ML pipeline
The final step in our predictive pipeline is running the BigQuery ML models. The bottleneck was the volume of data we needed to aggregate and prepare before the model could run.
We accelerated the upstream data preparation on the Tau T2A instances using optimized Python libraries that use Arm's architectural features, such as NEON vectorization. This reduced the time required to write the processed data to BigQuery. This change allowed the BigQuery ML jobs to start and finish faster.
Total = Tingestion + Tprocessing(Arm) + TML_inference
The reduction in Tprocessing(Arm) directly lowered overall data-to-insight latency.
Key implementation steps
- CI Infrastructure overhaul: We migrated our build process to create native Arm64 Docker images using a custom Cloud Build worker pool on Arm instances.
- GKE node migration: We deployed our analytical processing workers to a dedicated GKE Node Pool running the Tau T2A machine series.
- Technical deep dive: The Arm-Native Workflow on GCP.
Phase 1: Custom Arm64 Pool and GKE deployment
We configured our GKE cluster with a dedicated node pool for our data workers. This ensured they ran natively on Arm.
- Tau T2A architecture proof: We created a dedicated node pool named tau-t2a-processing-pool.
- Node selector implementation: In our Kubernetes Deployment manifest, we added nodeSelector to run the workload on the Arm64 architecture. This prevents fallback to x86 nodes.
# Minimal Arm64 base image for Python stream processing workers
FROM arm64v8/python:3.9-alpine
WORKDIR /app
# Install necessary build dependencies for data libraries (pandas/numpy)
RUN apk add --no-cache g++ freetype-dev openblas-dev
COPY requirements.txt .
RUN pip install --no-cache-dir -r requirements.txt
COPY . .
# Run the accelerated data transformation worker
CMD ["python", "stream_worker.py"]
apiVersion: apps/v1
kind: Deployment
metadata:
spec:
replicas: 5
selector:
matchLabels:
app: data-processor
template:
metadata:
labels:
app: data-processor
spec:
containers:
- name: arm-worker-container
image: gcr.io/stdio-x-labs/analytics-worker:arm64-latest
resources:
requests:
memory: "8Gi"
cpu: "2"
# Critical implementation: Force workload onto the Arm64 architecture
nodeSelector:
kubernetes.io/arch: arm64
cloud.google.com/machine-family: t2a
Impact: Significantly outperforming projections
Eight months after implementing the Arm-accelerated data processing layer on Google Cloud, the results fundamentally changed our service offering and unit economics.
Financial transformation
n2-standard-4 against Tau T2A. Note: The comparison is based on on-demand pricing for standard general-purpose workloads in us-central1.
| Metric | x86 (n2-standard-4) | Arm (Tau T2A) | Improvement |
| Instance specifications | 4 vCPU, 16GB RAM | 4 vCPU, 16GB RAM | - |
| Hourly compute cost | $0.1970/hr | $0.1540/hr | ↓ ~22% Lower |
| Daily compute spend | $94.56 (Cluster) | $73.92 (Cluster) | ↓ ~22% Savings |
| Annual savings | - | $7,500+ | - |
The substantial savings allowed stdio x labs to maintain competitive pricing for event organizers and invest in new platform features.
2026 Architecture update: The move to Axion (C4A)
We initially used the Tau T2A (Ampere Altra) series to validate the Arm architecture. The platform landscape has since evolved.
As of early 2026, we are upgrading our production clusters to Google custom Axion-based C4A instances. Early benchmarks indicate C4A provides:
- 50% higher performance than the comparable x86 instances.
- 60% higher energy efficiency, which aligns with our sustainability goals.
Recommendation for developers: If you replicate this architecture today, we recommend deploying directly on C4A (performance) or N4A (general purpose) instances instead of T2A. This approach maximizes price-performance benefits from Google custom silicon.
Performance breakthrough:
| Metric | X86 pipeline latency | Arm pipeline latency | Improvement |
| Real-time insight latency | 12 minutes | 7.2 minutes | ↓ 40% faster |
| Peak data throughput | 1.1m events/hr | 1.5m events/hr | ↑ 36% higher throughput |
| Dashboard update speed | Every 30 minutes | Every 5 minutes | Enabled near-real-time action |
These performance improvements are not only technical gains. They are a competitive advantage. Event organizers can now adjust ticket pricing or run last-minute flash sales based on data that updates in minutes rather than hours.
Business impact that mattered
The technical improvements on Google Cloud had a direct, measurable impact on our business:
- Organizer conversion: Real-time insights became a key selling point. This contributed to a 25% increase in conversion rate for large-scale events that rely on predictive analytics.
- Operational confidence: Lower unit costs and higher throughput gave us the confidence to pursue large music festivals and sporting events without fear of cost overruns or pipeline failure.
- Enhanced engagement: Faster response to audience data saw a 15% increase in total ancillary revenue, including VIP upgrades and merchandise sales. This growth was driven by relevant, real-time prompts delivered through our engagement tools.
By adopting Arm-native compute on Google Cloud, stdio x labs has positioned SoldOutAfrica as the leader in data-driven event management, providing the speed and cost efficiency that creators need to thrive.
“Brilliant data is useless if it is not fast enough to act upon" – Pascal Mudimba
About the author
Pascal Mudimba is the Co-founder and CTO of stdio x labs, specializing in scalable cloud architectures and real-time data platforms. Bridging his passion for high-performance systems with aviation, he is currently pursuing his Flight Dispatcher license and ATPL ground school at the Kenya Airways Pride Centre.
Links
Arm-BigQuery-ML-on-Google-Cloud on GitHub
Turbocharge Your SQL: The Dummy’s Guide to Switching BigQuery ML to Arm and Saving
