HomeCommunityCommunity Blog
September 6, 2021
The Arm Community is back online and upgraded
The Arm Community is back online following an upgrade. Learn more here.
By Oliver Beirne
Reading time 1 minute
Hello
We are upgrading the community to a new version. This means the community will be offline from 9am until 4pm BST on Tuesday September 14.
The upgrade mainly focuses on the backend of the platform, fixing some known bugs and also providing some new features (mostly for the administration of the platform). Probably the most significant change will be the fixing of an issue in the search bar. Users used to be kicked out of the search bar after entering a few characters, and had to click back in to complete their search. While search has always worked fine, this is an annoying user experience, so I am very happy to get this one resolved.
If you need support while the Community is offline please email support@arm.com.
We are back online, thanks for your patience while we upgraded the platform and did some testing to ensure everything is working as corrected. As mentioned above, the biggest change for you is that search is now working normally! It sounds like a small improvement but I have already enjoyed using it to find content and places.
The team has done a lot of testing to ensure the community is working correctly. If you see anything that is either not working properly or not the same as before then please let me know in the comments below.
Thanks again
Oli
