HomeCommunityArm Education
April 25, 2025
A lifelong circular model of education: from cradle to cradle
Discover how Arm Education is shaping cradle-to-cradle learning in tech, enabling flexible, lifelong pathways in AI, SoC, and embedded systems.
By Khaled Benkrid
Reading time 4 minutes
Today’s learners face a rapidly evolving technology landscape. In the age of generative AI, in particular, workforce development has taken on new urgency. As discussed in an earlier blog post, educators, industry leaders, and policy makers must work more closely than ever to ensure that talent supply matches the rapidly changing talent demands. Failure to do so has major economic, social, and political repercussions globally. In this blog post, I share how we at Arm Education & Academic Engagements, in collaboration with various partners, are enabling learners to navigate dynamic, modular, and meaningful learning journeys in computer engineering and informatics — from cradle to cradle.
Connecting the dots across levels and tracks
Our approach begins in the early years, where foundational skills in STEM and computational thinking lay the groundwork for future learning. As learners progress—typically around ages 14–16 in most education systems—a bifurcation into academic and vocational/technical tracks occurs. Figure 1. below depicts this using the UK qualifications levels, where the transition happens between Level 2 and Level 3 typically.
Figure 1: Circular lifelong learning journey
It is crucial to ensure learners do not hit dead ends. Whether they pursue academic or vocational routes, creating opportunities for cross-over and upward mobility is essential—because real learning journeys are rarely linear.
What is compelling is how skills at both ends of the journey often echo each other — skills developed in early years resurface in professional upskilling and lifelong learning later. For example, content designed for schools (like Introduction to AI) can be adapted for adult learners or professionals transitioning into tech roles. Moreover, requirements from one stage feed into both preceding stages and subsequent ones to enable learners to progress seamlessly through the pathways. This is why we think of our approach as a “cradle-to-cradle” (rather than “cradle-to-grave”) whereby content is recycled and repurposed throughout in a circular way.
Linking to the broader education & training ecosystem
 The following table gives examples of learning pathways developed by Arm and shows how this approach can link to content from different providers.
ML/AI Pathway Digital/SoC design pathway Embedded Systems pathway
Entry level/ skills for life Prompt Engineering (Concept)
Level 1 MicroCourse
Level 2 Programming with MicroPython
RaspberryPi Pico Projects for Schools
Arduino MKR Projects
Level 3 Intro to AI Intro to Microprocessors Arduino MKR Projects
Level 4 Intro to Computer Architecture
Computer Architecture Essentials
Beginner’s Guide to Embedded Systems
Embedded Systems Essentials on Arm
Level 5 ML on Edge Introduction to SoC Design
VLSI Design
Fundamentals SoC Design
Digital Signal Processing
Efficient Embedded Systems
Embedded Systems
Fundamentals
Embedded Linux
RTOS
Advanced Embedded Systems on Arm
Level 6 AI / LLMs on Mobile Advanced SoC Design EK
Modern SoC
Design
SoC
Design RB
Level 7 AI on Arm
Developer Program ML/AI Modules
Arm Training materials
Arm Helium Technology M-Profile Vector Extension (MVE)
Developer Program Embedded Systems Modules
Level 8 "Advanced AI on Arm (concept)" SoCLabs
Skills for life Prompt Engineering (Concept)
Bridging to developer and professional training ecosystems
Working within various communities of practice, for example, EduLabs for STEM and computer engineering education, SoCLabs, or the Semiconductor Education Alliance for wider workforce development, we enable scalable mission-driven content and pedagogy/andragogy development with reuse, modularity, and content “translation” across levels. This speeds up the plugging of learning gaps, accelerates learning pathways development, reduces duplication, and makes the whole much more impactful than the sum of the parts. It extends across academic and professional development realms ensuring smoother transitions between formal education and training, and professional practice, in both directions, at different stages of a lifelong learning journey.
Conclusion: A shared mission
Creating learning ecosystems that support lifelong development is both a challenge and an opportunity. A cradle-to-cradle approach fosters collaboration, efficiency, choice, and innovation. If you are a learner, checkout the various resources Arm have produced and join the various communities of practice we are supporting. If you are a content creator, educator, trainer, or enthusiast looking to contribute to a global learning transformation, let’s connect. Together, we can build inclusive, impactful, and future-ready learning pathways — one module at a time.
Contact Arm Education
1Log in to like this post
