Mali-D37 Display Processor
Arm Mali-D37 display processor block diagram
About Mali-D37
Mali-D37 is the first entry-level/mainstream DPU based on the Komeda architecture. It is the lowest area DPU with a rich feature set and high performance for entry-level and mainstream devices. Mali-D37 targets the devices where area matters most and is optimised for 1080p (full HD) to 2K resolution single displays. Mali-D37 is configurable to an area of less than 1mm2 on 16nm technology (for comparison, this is approximately 40 percent the size of the premium Mali-D71 DPU). This is achieved through the single display pipeline of Mali-D37. When combined with Assertive Display and MMU-600, the small DPU can provide the end user with exceptional visuals all while reducing memory latency and bandwidth.
Contact us
Specifications
Features Description
Implementation Single display output, compatible with all major display standards, including HDMI, MIPI, VESA, CEA-861, ITU-R. Versatility to drive either VR Head-mounted displays or premium large or small screen displays.
Compatibility Display solution with Assertive Display 5 and MMU-600.
Optimized to work with Arm Mali GPUs and Video Processors.
Bandwidth Reduction AFBC 1.2 support enables system-wide bandwidth reduction of up to 50%.
Security Content is hardware protected right to the glass. The Arm Mali-D37 comes with a TrustZone secure layer for secure payment and is compatible with Arm GlobalPlatform™ Trusted User Interface and TrustZone Media Protection.
Composition 4 layers alpha-blended composition.
Simultaneous layer and pixel alpha blending enables window animations. Performs format conversions, composition and alpha-blending of mixed HDR and SDR layers simultaneously.
Scaling Scaling on the display processor reduces CPU/GPU power consumption. The Mali-D37 DPU performs high quality up-scaling (up to 64x) and down-scaling (up to 6x) in any ratio.
Resolution Configurations for 1080p and 2K resolutions.
Rotation 90°, 180° and 270° rotation are supported along with highly configurable cropping options.
Picture Quality With color enhancements, single pixel accuracy for smooth window transitions and horizontal and vertical edge sharpening.
Input/Output Wide range of input and output formats supported.
  • A mali gpu chip.
  • Arm Mali GPUs
    Including both graphics and GPU Compute technology, Mali GPUs offer a diverse selection of scalable solutions for low power to high performance smartphones, tablets and DTVs.
    Learn more
  • A chip used in augmented reality.
  • AFBC
    Arm Frame Buffer Compression. AFBC protocol addresses the difficulty of creating increasingly complex designs within the thermal limit of a mobile device.
    Learn more
Get Support
Community Forums
Answered Unity apk crashes on start with Vulkan interceptor
  • vulkan
  • Unity
  • Mali-G72
1 votes 9716 views 7 replies Latest yesterday by Peter Harris Answer this
Answered SIGSEGV in glCompileShader due to loop
  • Android OpenGL ES
  • Mali-T830
0 votes 617 views 2 replies Latest 3 days ago by Rutger Janssen Answer this
Suggested answer Mali T400 rendering speed limit with Wayland 0 votes 1187 views 5 replies Latest 4 days ago by Peter Harris Answer this
Answered What is mali-renderer? 0 votes 4945 views 1 replies Latest 16 days ago by Jörg Answer this
Answered How to get the source code for Mali GPU User-Space driver?
  • Mali OpenGL ES SDK for Android
  • Mali DDK for GPU (Utgard Architecture)
0 votes 1895 views 4 replies Latest 18 days ago by Cliff Lin Answer this
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" 0 votes 3867 views 2 replies Latest 26 days ago by Peter Harris Answer this
Answered Unity apk crashes on start with Vulkan interceptor Latest yesterday by Peter Harris 7 replies 9716 views
Answered SIGSEGV in glCompileShader due to loop Latest 3 days ago by Rutger Janssen 2 replies 617 views
Suggested answer Mali T400 rendering speed limit with Wayland Latest 4 days ago by Peter Harris 5 replies 1187 views
Answered What is mali-renderer? Latest 16 days ago by Jörg 1 replies 4945 views
Answered How to get the source code for Mali GPU User-Space driver? Latest 18 days ago by Cliff Lin 4 replies 1895 views
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" Latest 26 days ago by Peter Harris 2 replies 3867 views
