Mali-D51 Display Processor
Arm-MALI-D51 Block Diagram.
About Mali-D51
Arm Mali-D51 is one of the first Display Processors to bring the benefits of the innovative Komeda display architecture to mainstream devices. Mali-D51 offloads the GPU by performing composition, in-line rotation, high quality scaling gamma/de-gamma and other imaging processing before sending the final image to the screen.
Contact Us
Specification
Features Description
Implementation Dual Display output. Compatible with all major display standards, including HDMI, MIPI, VESA, CEA-861, ITU-R .
Compatibility Display solution with Assertive Display 5 and MMU-600. Optimized to work with Arm Mali GPUs and Video Processors.
Bandwidth Reduction AFBC1.2 support enables system-wide bandwidth reduction of up to 50%.
 Bus Interface   AMBA 4 AXI
Security Content is hardware protected right to the glass. The Arm Mali-D51 comes with a TrustZone secure layer for secure payment and is compatible with Arm GlobalPlatform™ Trusted User Interface and TrustZone Media Protection.
Composition Max of eight alpha-blended layers (2 can be video layers). Mixed HDR/SDR composition .
Scaling Scaling on the display processor reduces CPU/GPU power consumption. The Mali-D51 DPU can scale up to two layers in parallel. High quality up-scaling (up to 64x) and down-scaling (up to 6x) in any ratio .
Resolution Up to 2048 pixels wide with native 10-bit display output support.
Rotation 90°, 180° and 270° rotation is supported along with highly configurable cropping options. In-line rotation of up to 8x AFBC layers.
Picture Quality With color enhancements, single pixel accuracy for smooth window transitions and edge sharpening .
Input/Output Wide range of input and output formats supported.
  • A mali gpu chip.
  • Arm Mali GPUs
    Including both graphics and GPU Compute technology, Mali GPUs offer a diverse selection of scalable solutions for low power to high performance smartphones, tablets and DTVs.
    Learn more
  • A chip used in augmented reality.
  • AFBC
    Arm Frame Buffer Compression. AFBC protocol addresses the difficulty of creating increasingly complex designs within the thermal limit of a mobile device.
    Learn more
Get Support
Community Forums
Suggested answer Mali T400 rendering speed limit with Wayland 0 votes 556 views 3 replies Latest 4 days ago by Peter Harris Answer this
Answered Unity apk crashes on start with Vulkan interceptor
  • vulkan
  • Unity
  • Mali-G72
1 votes 9263 views 5 replies Latest 7 days ago by Peter Harris Answer this
Answered What is mali-renderer? 0 votes 4717 views 1 replies Latest 9 days ago by Jörg Answer this
Answered How to get the source code for Mali GPU User-Space driver?
  • Mali OpenGL ES SDK for Android
  • Mali DDK for GPU (Utgard Architecture)
0 votes 1626 views 4 replies Latest 12 days ago by Cliff Lin Answer this
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" 0 votes 3639 views 2 replies Latest 19 days ago by Peter Harris Answer this
Answered G76 perf drop after Android Q update (bandwidth problem?)
  • Android OpenGL ES
  • performance
  • Mali-G76
0 votes 3705 views 1 replies Latest 19 days ago by Peter Harris Answer this
Suggested answer Mali T400 rendering speed limit with Wayland Latest 4 days ago by Peter Harris 3 replies 556 views
Answered Unity apk crashes on start with Vulkan interceptor Latest 7 days ago by Peter Harris 5 replies 9263 views
Answered What is mali-renderer? Latest 9 days ago by Jörg 1 replies 4717 views
Answered How to get the source code for Mali GPU User-Space driver? Latest 12 days ago by Cliff Lin 4 replies 1626 views
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" Latest 19 days ago by Peter Harris 2 replies 3639 views
Answered G76 perf drop after Android Q update (bandwidth problem?) Latest 19 days ago by Peter Harris 1 replies 3705 views
