Mali-D71 Display Processor
About Mali-D71
The Arm Mali-D71 display processor is one of the first generation Arm Mali display processor to be built on the innovative Komeda architecture. This processor is designed to address the bandwidth, throughput and latency challenges of next generation display trends such as virtual reality and HDR. It solves complex scenes and drives displays for resolutions up to 4K at 120FPS with a single pass through memory. Mali-D71 is an important companion to the Mali-GPU in the modern multimedia suite because it limits the GPU workload to offer system power savings of more than 30% compared to existing 4K solutions.
Contact Us
Specification
Features Description
Implementation Dual Display output, 4K or 2K configuration, Compatible with all major display standards, including HDMI, MIPI, VESA, CEA-861, ITU-R.
Compatibility Display solution with Assertive Display 5 and MMU-600. Optimized to work with Arm Mali GPUs and Video Processors.
Bandwidth Reduction AFBC1.2 support enables system-wide bandwidth reduction of up to 50%.
Security Content is hardware protected right to the glass. The Arm Mali-D71 comes with a TrustZone secure layer for secure payment and is compatible with Arm GlobalPlatform™ Trusted User Interface and TrustZone Media Protection.
Composition Max of eight alpha-blended layers (4 can be video layers). Mixed HDR/SDR composition.
Scaling Scaling on the display processor reduces CPU/GPU power consumption. The Mali-D71 DPU can scale up to four layers in parallel, or split the layer across multiple engines to save power. High quality up-scaling (up to 64x) and down-scaling (up to 6x) in any ratio.
Resolution Up to 4K with high color depth. 10-bit display output is supported.
Rotation 90°, 180° and 270° rotation is supported along with highly configurable cropping options.
Picture Quality With color enhancements, single pixel accuracy for smooth window transitions and horizontal and vertical edge sharpening.
Input/Output Wide range of input and output formats supported.
  • A mali gpu chip.
  • Arm Mali GPUs
    Including both graphics and GPU Compute technology, Mali GPUs offer a diverse selection of scalable solutions for low power to high performance smartphones, tablets and DTVs.
    Learn more
  • A chip used in augmented reality.
  • AFBC
    Arm Frame Buffer Compression. AFBC protocol addresses the difficulty of creating increasingly complex designs within the thermal limit of a mobile device.
    Learn more
Get Support
Community Forums
Suggested answer Mali T400 rendering speed limit with Wayland 0 votes 783 views 4 replies Latest 19 hours ago by gchamp Answer this
Answered Unity apk crashes on start with Vulkan interceptor
  • vulkan
  • Unity
  • Mali-G72
1 votes 9293 views 5 replies Latest 9 days ago by Peter Harris Answer this
Answered What is mali-renderer? 0 votes 4738 views 1 replies Latest 11 days ago by Jörg Answer this
Answered How to get the source code for Mali GPU User-Space driver?
  • Mali OpenGL ES SDK for Android
  • Mali DDK for GPU (Utgard Architecture)
0 votes 1654 views 4 replies Latest 13 days ago by Cliff Lin Answer this
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" 0 votes 3658 views 2 replies Latest 21 days ago by Peter Harris Answer this
Answered G76 perf drop after Android Q update (bandwidth problem?)
  • Android OpenGL ES
  • performance
  • Mali-G76
0 votes 3802 views 1 replies Latest 21 days ago by Peter Harris Answer this
Suggested answer Mali T400 rendering speed limit with Wayland Latest 19 hours ago by gchamp 4 replies 783 views
Answered Unity apk crashes on start with Vulkan interceptor Latest 9 days ago by Peter Harris 5 replies 9293 views
Answered What is mali-renderer? Latest 11 days ago by Jörg 1 replies 4738 views
Answered How to get the source code for Mali GPU User-Space driver? Latest 13 days ago by Cliff Lin 4 replies 1654 views
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" Latest 21 days ago by Peter Harris 2 replies 3658 views
Answered G76 perf drop after Android Q update (bandwidth problem?) Latest 21 days ago by Peter Harris 1 replies 3802 views
