Mali-D77 Display Processor
Arm Mali-D77 Block Diagram Image
About Mali-D77
The Arm Mali-D77 DPU is the second-generation premium Mali display processor to be built on the innovative Komeda architecture. Mali-D77 adds Virtual Reality (VR) processing functions on top of Mali-D71. It has the versatility to drive either VR head-mounted displays (HMDs) or standard large and small screen premium displays. The display processor is designed to improve the overall user experience for VR head-mounted displays by eliminating motion sickness and image artefacts, such as motion blur and screen door effect. This is made possible by enabling higher display resolutions and frames rates (up to 4K90), lowering the motion-to-photon latency and improving the image quality.
Mali-D77 is an important companion to Mali GPUs, as it limits the GPU workload through offering considerable system power savings to existing 4K solutions. Enabling powerful untethered VR devices that have better performance for a longer duration of time.
Contact us
Specifications
Features Description
Implementation Dual or single Display output, compatible with all major display standards, including HDMI, MIPI, VESA, CEA-861, ITU-R.
Versatility to drive either VR Head-Mounted Displays or premium large or small screen displays.
Compatibility Display solution with Assertive Display 5 and MMU-600.
Optimized to work with Arm Mali GPUs and Video Processors.
Bandwidth Reduction AFBC1.2 support enables system-wide bandwidth reduction of up to 50%.
Security Content is hardware protected right to the glass. The Arm Mali-D77 comes with a TrustZone secure layer for secure payment and is compatible with Arm GlobalPlatform™ Trusted User Interface and TrustZone Media Protection.
Composition Composition of up to 4 VR layers Composition of up to 8 non-VR layers (4 can be video layers).
Mixed HDR/SDR composition.
Scaling Scaling on the display processor reduces CPU/GPU power consumption. The Mali-D77 DPU can scale up to four layers in parallel, or split the layer across multiple engines to save power.
High quality up-scaling (up to 64x) and down-scaling (up to 6x) in any ratio.
VR Processing Functions Lens Distortion Correction (LDC)
Chromatic Aberration Correction (CAC)
Asynchronous TimeWarp (ATW)
Vignette
Clamp-to-edge
Resolution Optimized for 3Kp120 (4Kp90 capable) for VR Head-Mounted displays. Up to 4K @ 120 fps for standard displays. Wide colour gamut and High Dynamic Range supported.
Rotation 90°, 180° and 270° rotation is supported along with highly configurable cropping options.
Picture Quality With color enhancements, single pixel accuracy for smooth window transitions and horizontal and vertical edge sharpening.
Input/Output Wide range of input and output formats supported.
  • A mali gpu chip.
  • Arm Mali GPUs
    Including both graphics and GPU Compute technology, Mali GPUs offer a diverse selection of scalable solutions for low power to high performance smartphones, tablets and DTVs.
    Learn more
  • A chip used in augmented reality.
  • AFBC
    Arm Frame Buffer Compression. AFBC protocol addresses the difficulty of creating increasingly complex designs within the thermal limit of a mobile device.
    Learn more
Get Support
Community Forums
Suggested answer Mali T400 rendering speed limit with Wayland 0 votes 371 views 3 replies Latest 9 hours ago by Peter Harris Answer this
Answered Unity apk crashes on start with Vulkan interceptor
  • vulkan
  • Unity
  • Mali-G72
1 votes 9148 views 5 replies Latest 3 days ago by Peter Harris Answer this
Answered What is mali-renderer? 0 votes 4667 views 1 replies Latest 5 days ago by Jörg Answer this
Answered How to get the source code for Mali GPU User-Space driver?
  • Mali OpenGL ES SDK for Android
  • Mali DDK for GPU (Utgard Architecture)
0 votes 1554 views 4 replies Latest 7 days ago by Cliff Lin Answer this
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" 0 votes 3588 views 2 replies Latest 15 days ago by Peter Harris Answer this
Answered G76 perf drop after Android Q update (bandwidth problem?)
  • Android OpenGL ES
  • performance
  • Mali-G76
0 votes 3662 views 1 replies Latest 15 days ago by Peter Harris Answer this
Suggested answer Mali T400 rendering speed limit with Wayland Latest 9 hours ago by Peter Harris 3 replies 371 views
Answered Unity apk crashes on start with Vulkan interceptor Latest 3 days ago by Peter Harris 5 replies 9148 views
Answered What is mali-renderer? Latest 5 days ago by Jörg 1 replies 4667 views
Answered How to get the source code for Mali GPU User-Space driver? Latest 7 days ago by Cliff Lin 4 replies 1554 views
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" Latest 15 days ago by Peter Harris 2 replies 3588 views
Answered G76 perf drop after Android Q update (bandwidth problem?) Latest 15 days ago by Peter Harris 1 replies 3662 views
