Specifications
The Arm Mali-470 ultra low power GPU doubles the energy efficiency of the previous Utgard based Mali GPUs. Reducing the cost of both implementation and operation, the Mali-470 delivers superior energy efficiency across 1–4 core implementations. It is the first Mali GPU designed specifically for the power-sensitive requirements of wearable and IoT devices.
Key Benefits of Mali-470:
- Maximizes battery life with minimal thermal implications.
- Expands the smartphone user experience to wearables and IoT.
- Maximum efficiency with low memory fragmentation, reduced integration time and cost, reduced support burden.
Arm Mali-470 GPU
| Features | Value | Description |
| Anti-Aliasing |
4x AA. 16x AA. |
4x Multi-Sampling with virtually no performance drop. 16x AA outperforming all implementations of comparable quality. |
| API Support |
OpenGL ES 1.1/2.0. |
Full support for next-generation and legacy 2D/3D graphics applications. |
| Bus Interface |
AMBA AXI. |
Compatible with a wide range of bis interconnect and peripheral IPs. |
| L2 Cache |
8KB - 256KB |
Configurable L2 cache optimized for graphics data traffic. |
| Memory System |
MMU. |
Memory Management Unit. |
| Multi-core Scaling |
1 to 4 cores. |
A single IP covering a wide range of markets and price/performance points. |
Performance - Mali-470 (MP1)
| Feature | Value | Description |
| Frequency |
250MHz
650MHz |
in 40nm LP
in 28nm HPM |
| Throughput |
27Mtri/s, 250Mpix/s
71Mtri/s, 650Mpix/s |
in 40nm LP
in 28nm HPM |
