Specifications
The Arm Mali-G510 GPU is the second generation Valhall-based GPU for the mainstream market, which offers the highest level of product configurability and granularity of any Mali GPU. Engineered to align with more modern APIs such as Vulkan, Mali-G510 enables enhanced experiences for the mass market with fresh features from premium GPUs such as Command Stream Frontend and Asynchronous Top Level. On top of these features, it provides more enhanced formats for better HDR support, Arm Frame Buffer Compression (AFBC) uncompressed buffers and Arm Fixed Rate Compression (AFRC). With a performance uplift of 100%, and 22% energy efficiency improvements on previous generations of mainstream Mali GPUs, Mali-G510 brings quality graphics to emerging markets.
Arm is focused on delivering a Total Compute solution for our ecosystem, including custom Cortex-X CPUs, Cortex-A CPUs, Mali GPUs, Ethos NPUs, CoreLink and CoreSight System IP. Mali-G510 provides the end user with a stunning graphics experience.
Mali-G510 GPU Diagram
Arm Mali-G510 GPU
Features Value Description
Anti-aliasing 4x MSAA
8x MSAA
16x MSAA
4x Multi-Sampling Anti-Aliasing (MSAA) with minimal performance drop
API support
OpenGL® ES 1.1, 2.0, 3.1, 3.2
Vulkan 1.1, 1.2
OpenCL™ 1.1, 1.2, 2.0 Full profile
Renderscript
Full support for next-generation and legacy 2D/3D graphics applications
Bus interface AMBA®4 ACE, ACE-LITE, and AXI Compatible with a wide range of bus interconnect and peripheral IP
L2 cache Configurable 256KB – 1024KB
2x128KB for 2 cores
2x256KB for 3-4 cores
4x256KB for 5-6 cores
Scalability 10 configurations achieved with 2 to 6 quad-pixel cores
Optimized for high area and energy efficiency to address mainstream device requirements
Adaptive Scalable Texture Compression (ASTC) Low Dynamic Range (LDR) and High Dynamic Range (HDR).
Supports both 2D and 3D images.
ASTC offers several advantages over existing texture compression schemes by improving image quality, reducing memory bandwidth and thus energy use
Arm Frame Buffer Compression (AFBC) Version 1.3.2
4x4 pixel block size
AFBC is a lossless image compression format that provides random access to pixel data to a 4x4 pixel block granularity. It is employed to reduce memory bandwidth both internally within the GPU and externally throughout the SoC
Arm Fixed Rate Compression (AFRC) Version 1.0
AFRC is a lossy image compression format. AFRC can be used for compressing external texture inputs and framebuffer outputs from the GPU. Configurable compression ratio provides guaranteed bandwidth reduction for such surfaces and memory footprint saving.
Transaction Elimination 16x16 pixel block size Transaction Elimination spots the identical pixel blocks between two consecutive render targets and performs a partial update to the frame buffer with the changed pixel blocks only, which reduces memory bandwidth and thus energy.
Smart Composition  16x16 pixel block size Smart Composition extends the concept of Transaction Elimination to every stage of UI composition. Identical pixel blocks of input surfaces are not read, not processed for composition and not written to final frame buffer.
Foveated Rendering    3 levels of quality possible   Foveated Rendering allows VR application to specify the shading rate to be used in each part of the screen. This helps the developer to reduce the workload of VR applications by selectively define the part of the screen that require less work from the GPU due to distortion introduced by the VR headset lenses.
