Mali Midgard Architecture Extensions
Midgard architectures includes Mali-T600, Mali-T700 and Mali-T800 Series GPUs.
The below extensions are supported in the r5p1 driver release.
OpenGL ES extensions
GL_OES_blend_equation_separate
GL_OES_blend_func_separate
GL_OES_blend_subtract
GL_OES_byte_coordinates
GL_OES_compressed_ETC1_RGB8_texture
GL_OES_compressed_paletted_texture
GL_OES_draw_texture
GL_OES_extended_matrix_palette
GL_OES_fixed_point
GL_OES_framebuffer_object
GL_OES_matrix_get
GL_OES_matrix_palette
GL_OES_point_size_array
GL_OES_point_sprite
GL_OES_query_matrix
GL_OES_read_format
GL_OES_single_precision
GL_OES_stencil_wrap
GL_OES_texture_cube_map
GL_OES_texture_mirrored_repeat
GL_OES_EGL_image
GL_OES_depth24
GL_OES_element_index_uint
GL_OES_fbo_render_mipmap
GL_OES_mapbuffer
GL_OES_rgb8_rgba8
GL_OES_stencil8
GL_OES_texture_3D
GL_OES_texture_npot
GL_OES_vertex_half_float
GL_OES_depth_texture
GL_OES_packed_depth_stencil
GL_OES_standard_derivatives
GL_OES_get_program_binary
GL_OES_EGL_sync
GL_OES_vertex_array_object
GL_OES_EGL_image_external
GL_OES_surfaceless_context
GL_OES_required_internalformat
GL_OES_depth_texture_cube_map
GL_OES_texture_compression_astc
GL_OES_shader_image_atomic
GL_OES_texture_stencil8
GL_OES_texture_storage_multisample_2d_array
GL_EXT_texture_type_2_10_10_10_REV
GL_EXT_texture_format_BGRA8888
GL_EXT_discard_framebuffer
GL_EXT_blend_minmaxGL_EXT_read_format_bgra
GL_EXT_occlusion_query_boolean
GL_EXT_texture_rg
GL_EXT_sRGB
GL_EXT_multisampled_render_to_texture
GL_EXT_texture_storage
GL_EXT_disjoint_timer_query
GL_EXT_texture_sRGB_decode
GL_EXT_sRGB_write_control
GL_EXT_shader_pixel_local_storage
GL_ARM_mali_shader_binary
GL_ARM_rgba8
GL_ARM_mali_program_binary
GL_ARM_shader_framebuffer_fetch
GL_ARM_shader_framebuffer_fetch_depth_stencil
GL_KHR_texture_compression_astc_ldr
GL_KHR_debug
GL_KHR_blend_equation_advanced
OpenCL extensions
cl_khr_global_int32_base_atomics
cl_khr_global_int32_extended_atomics
cl_khr_local_int32_base_atomics
cl_khr_local_int32_extended_atomics
cl_khr_byte_addressable_store
cl_khr_fp64
cl_khr_int64_base_atomics
cl_khr_int64_extended_atomics
cl_khr_fp16
cl_khr_gl_sharing
cl_khr_icd
cl_khr_egl_event
cl_khr_egl_image
cl_arm_core_id
cl_arm_printf
