Mali-V61 Video Processor
Mali-V61 Block Diagram.
About Mali-V61
Arm Mali-V61 is a flexible and scalable multi-standard video processing solution, designed for encoding/decoding throughput between 1080p and 4K at up to 120 frames per second, dependent on configuration. The Mali-V61 includes 10-bit HEVC and VP9 encoding that scales across all levels and price points for mobile and home SoC requirements.
Contact Us
Key Features
  • Multi-standard, scalable, flexible video IP for encoding and decoding.
  • Supports HEVC, H.264, VP9, VP8, encode & decode, and legacy decoders.
  • One scalable video solution to address mobile and home multimedia SoCs.
Key Benefits
  • A power-efficient multi-video codec solution.
  • Supports VP9, 4K media.
  • Integrated with Mali graphics and display technology.
Specification
 Features Value
Description
API Support
For encode and decode : VP9 10-bit, VP9 8-bit, HEVC Main 10, HEVC Main, H.264, VP8, JPEG. Decode only : MPEG4, MPEG2, VC-1/WMV, Real, H.263 Driver and video streaming infrastructure based on OpenMAX™ which runs on the host CPU.
Bus Interface
AMBA AXI Compatible with a wide range of bus interconnect and peripheral IP.
Memory System
MMU Built-in Memory Management Unit (MMU) to support virtual memory.
Performance 1080p60 to 4K120 Scalable from one to eight cores with multiple performance points.
  • A mali gpu chip.
  • Arm Mali GPUs
    Including both graphics and GPU Compute technology, Mali GPUs offer a diverse selection of scalable solutions for low power to high performance smartphones, tablets and DTVs.
    Learn more
  • Arm Mali DPUs
    The Mali Display Processors bring composition, scaling, rotation and image post-processing tasks from the GPU on to a dedicated processor to maximize device battery life.
    Learn more
Get Support
Arm Support
Arm training courses and on-site system-design advisory services enable licensees to efficiently integrate the Mali-V61 Video Processor into their design.
Arm training courses Open a support case
Community Forums
Suggested answer Mali T400 rendering speed limit with Wayland 0 votes 784 views 4 replies Latest 19 hours ago by gchamp Answer this
Answered Unity apk crashes on start with Vulkan interceptor
  • vulkan
  • Unity
  • Mali-G72
1 votes 9293 views 5 replies Latest 9 days ago by Peter Harris Answer this
Answered What is mali-renderer? 0 votes 4738 views 1 replies Latest 11 days ago by Jörg Answer this
Answered How to get the source code for Mali GPU User-Space driver?
  • Mali OpenGL ES SDK for Android
  • Mali DDK for GPU (Utgard Architecture)
0 votes 1654 views 4 replies Latest 13 days ago by Cliff Lin Answer this
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" 0 votes 3658 views 2 replies Latest 21 days ago by Peter Harris Answer this
Answered G76 perf drop after Android Q update (bandwidth problem?)
  • Android OpenGL ES
  • performance
  • Mali-G76
0 votes 3802 views 1 replies Latest 21 days ago by Peter Harris Answer this
Suggested answer Mali T400 rendering speed limit with Wayland Latest 19 hours ago by gchamp 4 replies 784 views
Answered Unity apk crashes on start with Vulkan interceptor Latest 9 days ago by Peter Harris 5 replies 9293 views
Answered What is mali-renderer? Latest 11 days ago by Jörg 1 replies 4738 views
Answered How to get the source code for Mali GPU User-Space driver? Latest 13 days ago by Cliff Lin 4 replies 1654 views
Answered Arm Offline Comlier's Performance analysis Not Including "Instructions Emitted" Latest 21 days ago by Peter Harris 2 replies 3658 views
Answered G76 perf drop after Android Q update (bandwidth problem?) Latest 21 days ago by Peter Harris 1 replies 3802 views
