Getting Started
The Arm CoreLink Network Interconnect (NIC) family offers highly configurable topology with Network on Chip (NoC)-like properties that enable you to build high performance, optimized, AMBA-compliant SoC connectivity. The CoreLink NIC family is configurable across a wide range of applications from a single bridge component, for example an AHB to AXI protocol bridge, to a complex infrastructure that consists of up to 128 masters and 64 slaves in a combination of different AMBA protocols.
  • CoreLink NIC-450 Network Interconnect Chip.
  • CoreLink NIC-450
    • Library of key interconnect IP that enables designers to build a scalable and configurable NIC.
    • Available with a tooling automation flow using CoreLink Creator that employs algorithms to accelerate configuration based on design requirements.
    • Enables integrated tooling Socrates DE (licensed separately) for configuring complex interconnect subsystem designs.
    • Includes all NIC-400 features.
  • CoreLink NIC-400 Network Interconnect Chip.
  • CoreLink NIC-400
    • Fully configurable, hierarchical, low latency, low power connectivity for AMBA 4 AXI4, AXI3, AHB-Lite and APB interfaces.
    • Scalable for multiple applications from simple single core designs, up to large coherent systems as a companion to CoreLink CCI and CCN coherent interconnects.
    NIC-400 TRM
NIC-450 and CoreLink Creator
CoreLink Creator with its harvesting flows and enhanced tooling environment provides significant improvements to configure NICs, which decreases time to market.
Functional enhancement in NIC-400r1 with QVN-terminate feature to resolve head-of-line blocking when accessing DRAM provide:
  • Improved support for QVN with DMC controllers using sideband QOSACCEPT signaling, supported in DMC-500 and other 3rd party DMC providers.
  • CPU latency reduction with QoS enhancements, designed and tested with Arm memory controllers such as CoreLink DMC-500.
Start designing now
Arm Flexible Access gives you quick and easy access to this IP, relevant tools and models, and valuable support. You can evaluate and design solutions before committing to production, and only pay when you’re ready to manufacture.
CoreLink ADB-400
The CoreLink ADB-400 AMBA Domain Bridge is an asynchronous bridge between two components or systems that can be in a different power, clock, or voltage domains.
The ADB-400 supports:
  • An optional configurable destination register for the payload of each channel.
  • Simple reset requirements.
  • A power management interface.
  • Dynamic Voltage and Frequency Scaling (DVFS).
  • Quality of Service (QoS) Virtual Network (QVN).
  • Clock status indication.
The ADB-400 consists of a slave domain and a master domain. The slave domain received transfers from the AMBA master and the master domain transmits transfers to an AMBA slave.
CoreLink XHB-400
The XHB converts AXI4 protocol to AHB-Lite protocol and has an AXI4 slave interface and an AHB-Lite master interface.
AXI4 slave interface: This connects to either the AXI4 master interface of a processor or to an AXI interconnect.
AHB-Lite master interface: This implements an AHB-Lite master to drive AHB-Lite subsystems.
XHB-400 TRM
NIC-450 Library of Interconnect IP
Network Interconnect NIC-400
Advanced Quality of Service QoS-400
 Virtual Networks QVN-400
 Thin Links TLX-400
 AMBA Domain Bridge ADB-400
 AXI-to-AHB Bridge XHB-400
 Low-power distributor LPD-500
Get support
Community Blogs
Community Forums
Answered ARM vs Thumb vs Thumb2 instruction set
  • T32 (Thumb)
0 votes 8520 views 2 replies Latest 11 hours ago by Kevin B Answer this
Answered ARM/THUMB instructions that change execution path?
  • Thumb
0 votes 61148 views 77 replies Latest 23 hours ago by jakebunt Answer this
Not answered ACE-Lite 0 votes 17 views 0 replies Started yesterday by Ishan Answer this
Not answered Porting to U-boot driver model and device tree control (for ARM-based design)
  • Peripheral Devices
  • U-Boot
0 votes 188 views 0 replies Started 2 days ago by Rob Damico Answer this
Not answered httpd web server on stm32f407vg
  • STM32 F4
0 votes 170 views 0 replies Started 2 days ago by rpj Answer this
Not answered AXI4 transaction attributes 0 votes 195 views 0 replies Started 6 days ago by Ravi V. Answer this
Answered ARM vs Thumb vs Thumb2 instruction set Latest 11 hours ago by Kevin B 2 replies 8520 views
Answered ARM/THUMB instructions that change execution path? Latest 23 hours ago by jakebunt 77 replies 61148 views
Not answered ACE-Lite Started yesterday by Ishan 0 replies 17 views
Not answered Porting to U-boot driver model and device tree control (for ARM-based design) Started 2 days ago by Rob Damico 0 replies 188 views
Not answered httpd web server on stm32f407vg Started 2 days ago by rpj 0 replies 170 views
Not answered AXI4 transaction attributes Started 6 days ago by Ravi V. 0 replies 195 views
