Getting Started
AMBA system controllers are a collection of controller IP that Arm offers. These controllers are for Direct Memory Access (DMA), Level 2 Cache, and peripherals. These controllers are low-power, high-performance IP cores that perform critical tasks within the AMBA system. Designed for optimal compatibility with Arm Cortex, Mali multimedia, and CoreLink System IP, they are the natural complement to interconnect and memory controllers.
DMA controllers
The Direct Memory Access (DMA) controller enables the movement of blocks of data from peripheral to memory, memory to peripheral, or memory to memory without burdening the processor. Efficient use of DMA can significantly improve system performance in multiple dimensions. For example, using a DMA controller can offload a processor and either reduce power consumption, or boost the processor performance, or a combination of both. AMBA DMA controllers are designed to complement both high-end and energy-efficient systems. They provide a centralized DMA processing capability that is high performance and highly flexible, and at the same time, is area efficient. Key product offerings for DMA controllers are:
  • CoreLink DMA-330: The DMA-330 is a high-performance DMA controller that can boost the performance and reduce the power consumption in AXI systems.  The DMA-330 is a highly configurable device to support a wide range of applications and architectures.  The DMA-330 is programmable to support scatter-gather, memory to memory, peripheral to memory, and memory to peripheral transfers, run-from-reset, security on channels, interrupts, and peripherals.
    Click to view the DMA-330 TRM.
  • PrimeCell Micro DMA-230: The DMA-230 is a low gate count (3-10k gates) micro-DMA engine targeting Cortex-M3 systems and other low-power and cost-sensitive applications. The device offers excellent performance at low gate count and all the code is stored in system RAM rather than in registers. Using this component enables Cortex-M1 and Cortex-M3 based systems to remain low cost through reduced gate count and enabling scaling down the frequency of the processor in the system for reducing overall power consumption.
    Click to view the DMA-230 TRM.
Start designing now
Arm Flexible Access gives you quick and easy access to this IP, relevant tools and models, and valuable support. You can evaluate and design solutions before committing to production, and only pay when you’re ready to manufacture.
Get support
Community Forums
Answered Keil MDK 5 – useful links that help getting started 0 votes 2403 views 3 replies Latest 1 months ago by rkopsch Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1484 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1258 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Forum FAQs
  • ARM Community
0 votes 2299 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1172 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Where should I ask my question?
  • ARM Community
0 votes 11609 views 5 replies Latest 7 months ago by Andy Neil Answer this
Answered Keil MDK 5 – useful links that help getting started Latest 1 months ago by rkopsch 3 replies 2403 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 1484 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 1258 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 2299 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 1172 views
Answered Where should I ask my question? Latest 7 months ago by Andy Neil 5 replies 11609 views
