The use of FPGA technology enables us to provide boards containing fully functional, tested examples of the newest Arm processors before any hard silicon devices are available from a foundry.
It is usual for an SMM to be constructed from one or more LogicTile Express boards. A SODIMM memory module is generally included, to provide the system SDRAM since this is not on the motherboard.
An SMM behaves like a Versatile Express CoreTile, which allows it to be mounted on the V2M-P1 motherboard for use as an off-the-shelf development system. PLLs in the FPGA are used to give the highest possible CPU speed for an FPGA implementation. As it is a drop in replacement for a CoreTile Express board, only a single set of off-board AMBA AXI buses are implemented.
SMMs are available in the Versatile Express range for the following Arm processors:
SMM Express for Cortex-R5 SMM Express for Cortex-R7
SMM name (short) SMM-R5 SMM-R7
Part number V2S-CR5-1000A V2S-CR7-1000A
PCB part number HBI-0192 HBI-217
Datasheet Datasheet   Datasheet
Manuals User Guide User Guide
Processor type Cortex-R5 Cortex-R7
Num CPUs, Speed Dual, 50MHz Dual, 40MHz
Processor Revision r1p2 r0p0
Coprocessors FPU FPU
Hardware required V2F-1XV5 V2F-2XV6
L1 Cache I/D 64KB/64KB 16KB/16KB
L2 Cache N/A N/A
TCM I/D 64KB x 2, per CPU 64KB x 2, per CPU
Memory 16 MB PSRAM 2GB DDR2 SODIMM
Memory speed 50MHz 125MHz
Bus Type AXI AXI
Int Bus Freq 50MHz 40MHz
Ext Bus Freq 25MHz (M), 35MHz (S) N/A
Supported baseboard V2M-P1 V2M-P1
Tool Support
Software Tools for Versatile Express
DS-5 Development Studio fully supports all Arm processors and IP as well as a wide range of third-party tools, operating systems and EDA flows. DS-5 represents a comprehensive range of software tools to create, debug and optimize systems built on Versatile Express boards.
It incorporates DS-5 Debugger, whose powerful and intuitive graphical environment enables fast debugging of bare-metal, Linux and Android native applications. DS-5 Debugger provides pre-defined configurations for LogicTile Express boards, for a quick and convenient way to start software development.
In addition, Streamline performance analyzer simplifies the identification of hot spots in software and load balancing between cores and clusters with a brilliantly intuitive graphical display.
Get support
Community Forums
Answered Where do I find presentations and photos from SC'18? 2 votes 4501 views 0 replies Started 1 years ago by John Linford Answer this
Not answered PCE is failed to find the DAP using DSTREAM-ST in DS-5
  • DS-5 Development Studio
  • DSTREAM
0 votes 13 views 0 replies Started 6 hours ago by jerry.xin Answer this
Suggested answer How to recover the Keil after uninstalling the LIC? 0 votes 91 views 3 replies Latest 7 hours ago by Andy Neil Answer this
Not answered Between osKernelInitialize() and osKernelStart() 0 votes 22 views 0 replies Started 7 hours ago by zunda Answer this
Suggested answer How do I exclude a Pack file from my build so I can replace with modified version in my folder? 0 votes 42 views 1 replies Latest 8 hours ago by Gunnar Bohlen Answer this
Discussion Looking for activation code of DS-5 Community Edition
  • Tool Licensing
  • DS-5 Community Edition
0 votes 21715 views 20 replies Latest 8 hours ago by Nouchi Answer this
Not answered Regarding Visibility of Multi Master ACE-Lite System 0 votes 22 views 0 replies Started 9 hours ago by RajaAC Answer this
Answered ARM/THUMB instructions that change execution path?
  • Thumb
0 votes 61130 views 77 replies Latest 9 hours ago by jakebunt Answer this
Not answered ACE-Lite 0 votes 14 views 0 replies Started 9 hours ago by Ishan Answer this
Not answered translation table APTable permission problem
  • Cortex-A57
  • Armv8-A
  • Linux
0 votes 20 views 0 replies Started 9 hours ago by raks8877 Answer this
Suggested answer USB Camera interface using keil IDE 0 votes 206 views 5 replies Latest 10 hours ago by Milorad Cvjetkovic Answer this
Suggested answer C++ header is requesting Rogue Wave
  • Keil MDK
0 votes 2185 views 9 replies Latest 11 hours ago by Tim Scherr Answer this
Answered Where do I find presentations and photos from SC'18? Started 1 years ago by John Linford 0 replies 4501 views
Not answered PCE is failed to find the DAP using DSTREAM-ST in DS-5 Started 6 hours ago by jerry.xin 0 replies 13 views
Suggested answer How to recover the Keil after uninstalling the LIC? Latest 7 hours ago by Andy Neil 3 replies 91 views
Not answered Between osKernelInitialize() and osKernelStart() Started 7 hours ago by zunda 0 replies 22 views
Suggested answer How do I exclude a Pack file from my build so I can replace with modified version in my folder? Latest 8 hours ago by Gunnar Bohlen 1 replies 42 views
Discussion Looking for activation code of DS-5 Community Edition Latest 8 hours ago by Nouchi 20 replies 21715 views
Not answered Regarding Visibility of Multi Master ACE-Lite System Started 9 hours ago by RajaAC 0 replies 22 views
Answered ARM/THUMB instructions that change execution path? Latest 9 hours ago by jakebunt 77 replies 61130 views
Not answered ACE-Lite Started 9 hours ago by Ishan 0 replies 14 views
Not answered translation table APTable permission problem Started 9 hours ago by raks8877 0 replies 20 views
Suggested answer USB Camera interface using keil IDE Latest 10 hours ago by Milorad Cvjetkovic 5 replies 206 views
Suggested answer C++ header is requesting Rogue Wave Latest 11 hours ago by Tim Scherr 9 replies 2185 views
