Beetle 3 Medium Circuit Board.
Getting Started
The Arm Beetle IoT evaluation board is built around the Arm CoreLink SSE-100 Subsystem, which allows design teams to create IoT endpoints faster and with lower risk. Arm’s scalable IP solutions are designed to target across the value chain, from sensors to servers. Arm’s IoT subsystem with Mbed OS is a complete reference system, that reduces the complexity and risk of a SoC design for IoT endpoints. The subsystem features a range of peripherals and interfaces. It is specifically designed for use with Cortex-M processors and Arm Cordio Bluetooth Smart Radio IP. Arm has taken this subsystem and generated a proof of concept test chip called Beetle.
Key benefits of the Arm Beetle board include:
  • Single-chip Cortex-M3 based IoT design
  • Features embedded Flash and Bluetooth
  • Evaluate and develop IoT applications
Applications
Evaluation of Arm IP for IoT in a system context.
Specifications
Board name (short)  Beetle
Part number V2M-Beetle-0340A
PCB number HBI-0295B
Datasheet V2M_Beetle_datasheet
Manuals Technical Reference Manual
Form factor
69 x 53mm (2.7 x 2.1 inches)
CPU
Arm Cortex-M3
Subsystem Arm CoreLink SSE-100 Subsystem
Radio Cordio BT4.2 Bluetooth Smart radio
Memory 256KB of embedded flash
  2MB of external QSPI flash
Debug
JTAG
SWD
  CMSIS-DAP with a virtual UART port
  4-bit TRACE
 Expansion GPIO
  UART
  SPI
  I2C
  Analog signals
Key product highlights
The central element of the platform is the IoT subsystem, which is pre-validated allowing the user to hit the ground running. Arm extended the IoT subsystem, attaching the Arm Cortex-M3 processor, the Arm Cordio Bluetooth Smart radio, the TSMC embedded flash and a host of other complementary peripherals to create the Beetle test-chip.
The design is fully compliant with Arm’s Mbed OS IoT software framework, which enables rapid development and prototyping. It is loaded with debug features including: JTAG, SWD, CMSIS-DAP and TRACE. The Beetle board has support for expansion using Arduino® headers. It is an ideal platform for the evaluation of an Arm CoreLink SSE-100 Subsystem IoT subsystem.
A microcontroller-based configuration mechanism provides an easy, USB-based, plug-and-play method for programming software and firmware into the system flash memory from an attached PC.
Get support
Community Forums
Answered Where should I ask my question?
  • ARM Community
0 votes 6019 views 3 replies Latest 2 months ago by Oliver Beirne Answer this
Answered Forum FAQs
  • ARM Community
0 votes 3339 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 515 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 574 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1025 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 651 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 994 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 6449 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 468 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 3255 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 628 views 0 replies Started 4 months ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 672 views 0 replies Started 4 months ago by Annie Answer this
Answered Where should I ask my question? Latest 2 months ago by Oliver Beirne 3 replies 6019 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 3339 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 515 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 574 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 1025 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 651 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 994 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 6449 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 468 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 3255 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 628 views
Answered Forum FAQs Started 4 months ago by Annie 0 replies 672 views
