Overview
Learn how to use Mali Offline Compiler to analyze the performance of shader programs. This example demonstrates how to visualize performance bottlenecks on a Mali GPU target.
Before you begin
  1. Download and install Arm Mobile Studio.
  2. On Linux or macOS, add the install location of Mali Offline Compiler to your PATH environment variable so that you can compile from any directory. If you installed on Windows using the installer, this step is done automatically.
    If you omit this step, you must navigate to the <install_location>/mali_offline_compiler directory each time you want to run Mali Offline Compiler.
  3. In a terminal, test that Mali Offline Compiler is installed correctly, by typing:
    malioc --help
    The --help option returns usage instructions and the full list of available options for the malioc command.
Note: On macOS, Mali Offline Compiler might not be recognised as an application from an identified developer. To enable Mali Offline Compiler, open System Preferences > Security & Privacy, and select  Allow Anyway for the 'malioc' item.
Compile your shader
The following Open GL ES fragment shader implements the horizontal pass of a 5-tap separable Gaussian blur, with an optional tone mapping stage implemented using a matrix multiply:
#version 310 es
#define WINDOW_SIZE 5
precision highp float;
precision highp sampler2D;
uniform bool toneMap;
uniform sampler2D texUnit;
uniform mat4 colorModulation;
uniform float gaussOffsets[WINDOW_SIZE];
uniform float gaussWeights[WINDOW_SIZE];
in vec2 texCoord;
out vec4 fragColor;
void main() {
   fragColor = vec4(0.0);
   // For each gaussian sample
   for (int i = 0; i < WINDOW_SIZE; i++) {
       // Create sample texture coord
       vec2 offsetTexCoord = texCoord + vec2(gaussOffsets[i], 0.0);
       // Load data and perform tone mapping
       vec4 data = texture(texUnit, offsetTexCoord);
       if (toneMap) {
           data *= colorModulation;
       // Accumulate result
       fragColor += data * gaussWeights[i];
  1. In a terminal window, enter the following command to instruct Mali Offline Compiler to compile the shader for a device with a Mali-G76 GPU:
    malioc -c Mali-G76 gauss_blur.frag
    This returns the following performance report:
    Mali Offline Compiler v7.0.0 (Build bc7a3e)
    Copyright 2007-2019 Arm Limited, all rights reserved
    Configuration
    Hardware: Mali-G76 r0p0
    Driver: Bifrost r19p0-00rel0
    Shader type: OpenGL ES Fragment
    Main shader
    Work registers: 32
    Uniform registers: 34
    Stack spilling: False
                                 A   LS    V    T  Bound
    Total Instruction Cycles:  4.5  0.0  0.2  2.5      A
    Shortest Path Cycles:      1.0  0.0  0.2  2.5      T
    Longest Path Cycles:       4.5  0.0  0.2  2.5      A
    A = Arithmetic, LS = Load/Store, V = Varying, T = Texture
    Shader properties
    Uniform computation: False
  2. Analyze the report. To decide which part of your shader code you need to optimize, identify the critical path units from the hardware units running in parallel. The performance table for the Main shader provides an approximate cycle cost breakdown for the major functional units in the design. For this shader you can see that:
    1. The shader is texture bound when not using tone mapping. T is the highest value for the shortest path, taking 0.5 cycles a sample for this 5-sample blur. This is as fast as the hardware texture filtering unit in a Mali-G76 can go.
    2. The shader is arithmetic bound when using matrix-based tone mapping. A is the highest value for the longest path when the conditional tone mapping block is executed.
For full details of all of the reported sections and fields, refer to the Mali Offline Compiler User Guide.
Optimize your shader program
Now you have identified the critical path, speed up the tone mapping to improve performance of the shader.
  1. The first change you can make is to reduce precision. Currently the tone mapping is using a highp (fp32) matrix operation, which has more precision than we need to generate an 8-bit per channel color output. Change the precision to “mediump” (fp16) float and sampler precision by modifying these two lines at the top of the shader:
    precision mediump float;
    precision mediump sampler2D;
    Just these two simple changes significantly reduce the cost of the longest path, as Mali GPUs can process twice as many fp16 operations per clock than fp32 operations.
                           A   LS    V    T   Bound
    Longest Path Cycles: 2.7 0.0 0.2 2.5 A
  2. After changing the precision, arithmetic is still the longest path. Move the tone mapping out of the accumulation loop, and apply it to the final color instead of the individual samples. This gives the final shader structure:
    // Tone map the final color
    if (toneMap) {
    fragColor *= colorModulation;
    This change reduces the arithmetic cost of the longest path to just a single shader core cycle, even if tone mapping is used. The slowest path is now texturing, which needs 2.5 cycles per fragment to load the 5 samples needed. You can not make this any faster, because this is the architectural performance of this particular shader core.
                                A   LS    V    T   Bound
    Total Instruction Cycles: 1.0 0.0 0.2 2.5 T
    Shortest Path Cycles: 0.5 0.0 0.2 2.5 T
    Longest Path Cycles: 1.0 0.0 0.2 2.5 T
Although the last optimization reduced the arithmetic cost from 2.7 cycles to 1.0 cycles, the shader throughput only improved from 2.7 cycles to 2.5 cycles per fragment because the bottleneck changed from A to T. However, reducing the load on any pipeline will improve energy efficiency and prolong battery life, so these types of optimizations are still worth making, even if they do not improve the headline performance.
Target-aware profiling
Different models of Mali GPU are tuned for different target markets, so they have different performance ratios between the functional units. Mali Offline Compiler enables you to test the performance of your shaders on different target GPUs.
For example, compiling the shader for a Mali-G31, which is designed for embedded use cases, and therefore has a lower ratio of arithmetic to texture performance, returns the following performance report:
                            A   LS    V    T   Bound
Total Instruction Cycles: 2.9 0.0 0.2 2.5 A
Shortest Path Cycles: 1.6 0.0 0.2 2.5 T
Longest Path Cycles: 2.9 0.0 0.2 2.5 A
For this GPU, the shader is still arithmetic bound, even with the optimizations applied.
Limitations
The performance reports generated by Mali Offline Compiler are based only on the shader source code visible to the compiler. They are not aware of the actual uniform values or texture sampler configuration for any specific draw call, or any data-centric effects such as cache miss overheads.
The texture format and the filtering type used, can impact texture unit performance. Trilinear filtering (GL_LINEAR_MIPMAP_LINEAR) takes twice as long as bilinear filtering (GL_LINEAR or GL_LINEAR_MIPMAP_NEAREST), and anisotropic filtering can be scaled by both the probe type and the number of anisotropic sample probes made. Mali Offline Compiler assumes simple bilinear filtering for all samples, which is the fastest type supported by the hardware. If you know a draw call is using trilinear filtering for texture samples, you should double the cycle cost of the texture accesses reported in the performance report.
Arm Streamline, also included with Arm Mobile Studio, samples performance data from the Mali GPU hardware while your application runs on your target device. You can supplement Mali Offline Compiler performance reports with this data. For example, measure the number of multi-cycle texture operations being performed to validate the assumption that all accesses in your application are bilinear accesses.
