Generate a performance summary
Overview Before you begin Capture a Streamline profile Generate a performance report Generate a JSON file Command options Related information
- In a terminal, navigate to the location of your Streamline capture file. This file is usually a Streamline
.apc
directory but can also be a.zip
file that has been exported from Streamline.
cd $HOME/Documents/my_captures
- Run Performance Advisor's
pa
command to generate an HTML report in the current location:
pa my_capture.apc [options]
You can pass options to the pa command, to control how it runs. For example, you can specify different output directory for the report, and metadata for the report, such as the application name, device name and build name, which are shown at the top of the report to help you identify the run:
pa my_capture.apc --directory=$HOME/Documents/Reports --application-name="My Game" --device-name="A50" --build-name="First Build"
For a full list of the available command options, refer to The pa command in the Performance Advisor user guide.
Note: If you are using an Arm Mobile Studio with a professional edition license to do system-wide profiling on a rooted device, you also need to specify the application name with the--process
option:
pa my_capture.apc --process=app.package.name [options]
The HTML report is saved to the current location, or to the directory that you specified with the
--directory
option. Double-click this file to view it in a browser.
