Capture a profile
- In Streamline, select the Start Capture button
to start capturing data from the target device. Specify the name and location on the host of the capture file that Streamline will create when the capture is complete. Streamline then switches to Live view and waits for you to start the application on the device.
- Start the application you want to profile. Live view shows charts for each counter that you selected. Below the charts is a list of running processes in your application with their CPU usage. The charts now start updating in real time to show the data that
gatord
captures from your running application:
- Unless you specified a capture duration, click Stop capture to end the capture
. Arm Streamline stores the capture file in the location you specified previously and then prepares the capture for analysis. When complete, the capture appears in the Timeline view.
- Choose the Switch and manage templates button
and select the same counter configuration template that you chose to create the capture.
