Choose a counter template
Counter templates are pre-defined sets of performance counters that enable you to perform an initial performance review of how the CPU and GPU behave when you run your application. Choose the most appropriate template for the GPU in your target device.
  1. From the Start tab, open the Counter configuration dialog by selecting Configure Counters.
    Streamline's configure counters button
  2. Choose Add counters from a template Add counters from a template button to see the list of available templates.
    Streamline's counter configuration dialog
  3. Choose a counter template appropriate for the target GPU in your target device. The number of counters in the template that your target device supports is shown next to each template. For example, here, 34 of the 38 available counters in the Mali Midgard template are supported in the connected device.
    Choosing a counter template in Streamline
    For detailed descriptions of all of the available counters for each Mali GPU, refer to the Mali GPU counter reference.
  4. Save your changes.
  5. Optionally, select Advanced Settings from the Start tab, to set additional capture options, including the sample rate and the capture duration.
    Streamline's advanced settings button
    Refer to Capture options in the Arm Streamline User Guide for more details.
Previous Next
