Configure your device
On your device:
  1. Ensure Developer Mode is enabled, then enable USB Debugging using Settings > Developer options.
  2. Connect the target to the host through USB.
  3. Run the adb devices command on the host to check that connection is successful. If successful, this command returns the ID of your target.
    adb devices
    List of devices attached
    ce12345abcdf1a1234       device
    You should also be able to run adb shell without issues.
  4. Install a debuggable application:
    • For Unity applications, select the Development Build option in Unity's Build Settings when building your application.
    • If you're not using Unity, ensure your application is marked as debuggable in the Android application manifest (see more on how to do this in the Android Studio documentation).
Previous Next
