Arm Mobile Studio Release History
Here, you can find details about what changed with each new release of Arm Mobile Studio.
To download the latest version, go to Downloads.
Arm Mobile Studio: 2020.3 December 11, 2020
What's new in 2020.3
This release of Arm Mobile Studio includes:
- Streamline, to profile application performance.
- Performance Advisor, to generate at-a-glance application performance summary reports.
- Graphics Analyzer, to debug graphics API usage.
- Mali Offline Compiler, to perform static analysis of GPU shader programs.
System Requirements
Arm Mobile Studio is officially supported on 64-bit versions of the following host platforms:
- Windows 10
- macOS 10.13 (High Sierra) or newer
- Linux Ubuntu 16.04 (Xenial Xerus) or newer
Arm Mobile Studio is supported on 32-bit and 64-bit versions of the following target platforms:
- Android 8.0 (Oreo) or newer
Not all Android devices provide complete performance data. Check our supported devices page to see which platforms we recommend.
Changes in this release
This release introduces the following changes and updates compared to Arm Mobile Studio 2020.2.
Arm Mobile Studio
- Samsung Galaxy A51 added as a supported device.
- Oppo Reno3 5G added as a supported device.
Streamline 7.5
- Android device connection can now be established using only the GUI. When you launch Streamline, you can connect to a device directly from the Start tab without the need to run the
gator_me.py
script. Watch this video to see how easy connection is, and refer to Get started with Streamline for full instructions.
Note: Thegator_me.py
script is still required for headless modes of operation. - Mali GPU configuration parameter's for shader core count, L2 cache slice count, and external bus width are now available as expression variables.
- Mali GPU template expressions for external memory stall percentages now correctly reflect the number of GPU cache slices in the target design.
- Mali GPU template expressions for external memory bandwidth counters now correctly reflect the GPU bus width in the target design.
- Mali GPU templates for the Valhall family now include a measure of the number of fragment using advanced shader-based blend functions.
Note: Streamline 7.5 can open capture files that were taken with previous versions, from version 6.9 onwards. Captures taken with Arm Development Studio can not be opened with an Arm Mobile Studio starter edition license. If you need to open captures taken with Arm Development Studio, you will need an Arm Mobile Studio professional edition license.Performance Advisor 1.3
Report chart visualizations can now be customized, allowing them to be tuned to their target audience.
- JSON reports can now be compared using the new diff report generator, allowing simple comparative analysis of two builds.
- Frame numbers are now displayed under each chart in the HTML file, and for each region in the JSON file.
Graphics Analyzer 5.7
- OpenGL ES applications on Android 8 or 9 no longer need an integrated interceptor library to be added at build time; the only requirement for any API or Android version is that the application is debuggable.
Mali Offline Compiler 7.3
- Input shaders can now be read from stdin instead of file; specify the input path as the "
" character. - Output reports can now be written to file instead of stdout; use the
-o
/-output
command line option. - SPIR-V binary modules are now auto-detected, and most shader properties are inferred from the module content. This significantly shortens the command lines needed for SPIR-V binary inputs.
- Process exit codes due to bad compiles (exit code 1) are now distinct from tool errors such a bad command line parameters (exit code 2). This helps integrating JSON reports into other tools more reliably; JSON reports are only produced by tool invocations returning exit code 0 or 1.
Get started
For instructions on how to install and get started with Arm Mobile Studio, refer to the following topics on the Arm Developer website:
Further learning resources including user guides, tutorials and videos are available on the Arm Developer website.
Feedback and support
For Arm Mobile Studio starter edition you can raise queries and support issues relating to both the tools and general performance analysis on the Arm Community website.
With an Arm Mobile Studio professional edition license, you get access to world-class Arm support. To raise a request for help, go to the Arm support portal.
Known issues
The issues listed here are new in this release. Refer to our FAQ page for answers to common problems and workarounds.
Arm Mobile Studio: 2020.2 September 03, 2020
What's new in 2020.2
System Requirements
- Windows 10
This release introduces the following changes and updates compared to Arm Mobile Studio 2020.1.
Streamline 7.4
- Improved device connection user interface and workflow. When you launch Streamline, you now see a Start tab that lists any connected devices, and enables you to quickly start capturing data. Refer to Connect Streamline to your device for details.
- You can now visualize Arm NN timeline trace data. This allows you see what your machine learning application, built with Arm NN, is doing, and how it is interacting with accelerator hardware such as the GPU.
Note: Streamline 7.4 can open capture files that were taken with previous versions, from version 6.9 onwards. Captures taken with Arm Development Studio can not be opened with an Arm Mobile Studio starter edition license. If you need to open captures taken with Arm Development Studio, you will need an Arm Mobile Studio professional edition license.Performance Advisor 1.2
- You can set per-frame performance budgets for a range of metrics, that are then shown on the charts in the Performance Advisor report.
Use the following command-line options when running the pa command to specify budgets:
--bandwidth-budget <value> --cpu-cycles-budget <value> --draw-calls-budget <value> --gpu-cycles-budget <value> --overdraw-budget <value> --pixels-budget <value> --primitives-budget <value> --shader-cycles-budget <value> --vertices-budget <value>
- Specify command-line options to the
pa
command, using a file containing a list of options. Refer to Command-line options configuration file in the Performance Advisor user guide.
- When using the
--clip-start
or--clip-end
options to define a specific region of the Streamline capture to analyze with Performance Advisor, you can now specify the frame number, instead of the timestamp in milliseconds. For example,--clip-end=7000f
ends the region at frame 7000. - Frame numbers are shown in the report.
- Wildcard operator support when manually defining regions start and end with a regions file. Refer to Specify a CSV file containing the regions in the Performance Advisor user guide.
- Improved region summary messaging in the report.
- Pretty-printed JSON is now an option and not the default for JSON reports. This makes the default JSON format consumable by 3rd party database and visualization tools such as ELK stack. If you want to output more human-readable pretty-printed JSON, use the
--pretty-print
option to the pa command. - Vertex data has been renamed to 'non-fragment'. Refer to Non-fragment bound for advice.
- Changes to command-line interface:
- The default setting for
--lwi-mode
is nownone
. This means that Performance Advisor will perform the capture without attempting to capture images of slow frames, and you no longer need to specify the--lwi-out-dir
option by default. If you want to see the frame capture images in the Performance Advisor report, you need to set--lwi-mode
tocapture
, and define an output directory for the frame images with--lwi-out-dir
. - The default setting for
--lwi
is nowon
--lwi-fps-threshold
is now 30.
- For Arm Mobile Studio Professional users, there’s a new tutorial and helper script, to help you set up automated performance analysis with Arm Mobile Studio as part of your continuous integration workflow.
Graphics Analyzer 5.6
- Improved device connection support. You no longer need to use the
aga_me.py
script, to connect to your device; this functionality is now part of the Device Manager, which is launched when you start Graphics Analyzer. Refer to Capture a trace for details.
- Updated API tracing support to include basic trace-only support for the latest Open GL ES extensions as well as for Vulkan 1.1, 1.2 and related extensions.
- Removed support for:
- Pre-Android 10 system-wide (rooted mode) tracing on Android targets.
- OpenCL tracing on Android targets.
- There's a new video to help you get up and running with Graphics Analyzer.
Mali Offline Compiler 7.2
- Mali Offline Compiler can now be used to generate reports for devices with Mali-G57, Mali-G68, Mali-G77 and Mali-G78 GPUs, based on Arm’s latest Valhall architecture. For arithmetic-heavy shaders you can now see the instruction cycles split by the arithmetic pipeline they are using: CVT, FMA, and SFU.
- Stack and register usage reporting for Mali Bifrost and Valhall GPUs has been improved:
- The number of work registers in use is now accurate, previously, this number would only report whether the number was below 32 or between 32 and 64.
- See whether any variables are spilled to stack memory, and how many bytes per thread are spilled.
- See the percentage of arithmetic operations that are performed efficiently, at 16-bit precision or lower.
- Shader properties are now reported to help you identify opportunities for optimization.
- For vertex shaders, Mali Offline Compiler reports separate performance tables for position and varying shaders.
- Information is listed for supported Vulkan SPIR-V feature level and extensions.
You can now export Mali Offline Compiler reports as machine-readable JSON files, so that you can build your own dashboard to monitor shader performance over time. To do this, run
malioc
with the--format json
option.
Get started
Known issues
Arm Mobile Studio: 2020.1 June 10, 2020
What's new in 2020.1
System Requirements
- Windows 10
This release introduces the following changes and updates compared to Arm Mobile Studio 2020.0.
This is the first release of Arm Mobile Studio professional edition, a licensing option to enable development teams to integrate performance analysis tools into their continuous integration workflow, enabling large-scale automated testing across multiple Android devices. If you would like to purchase professional edition, please submit a request using the form here.
Streamline 7.3
This release includes the following feature enhancements:
- Support for collecting performance counters on Arm Ethos NPUs via the ArmNN library.
- Support for the Exynos M5 microarchitecture (recognised by name only, no specific counters).
Note: Streamline 7.3 can open capture files that were taken with previous versions, from version 6.9 onwards. Captures taken with Arm Development Studio can not be opened with an Arm Mobile Studio starter edition license. If you need to open captures taken with Arm Development Studio, you will need an Arm Mobile Studio professional edition license.Performance Advisor 1.1
- Performance Advisor now supports captures taken with devices with Mali-G57 and Mali-G77 GPUs, based on Arm’s latest Valhall architecture. For arithmetic-heavy shaders you can now see the execution cycles split down by the arithmetic pipeline they are using, with CVT, FMA, and SFU cycles shown separately in the shader cycles per frame chart:
- A new chart to visualize CPU cycles per frame is available. Monitor FPS alongside the number of CPU cycles per frame so that you can look for areas of correlation that might indicate a CPU load problem:
- Generate a performance report from a section of a Streamline capture, by defining start and end times with a timestamp, or by defining annotated region names. Refer to section 6.3 in the Performance Advisor user guide.
- Use the
-mspf
option with thepa
command to display time per frame in milliseconds throughout the HTML report, instead of FPS. - For Android 10 devices, you can connect to your application running on the device using an Open GL ES or Vulkan layer library, instead of packaging the LWI library in your application. Use the
–lwi-gles-layer-lib
or–lwi-vk-layer-lib
options when running the connection script, to specify the path to the required layer library file. Refer to Get started with Performance Advisor for instructions. - You can now click and drag to zoom in on all line charts in the report, in the same way as you can with the FPS chart.
Performance Advisor reports have been refined to improve chart consistency, speed up analysis time, and to reduce the size of the generated report.
The JSON key
targetInfo
has changed todeviceInfo
. If you were using the JSON output format in a previous release of Arm Mobile Studio, you will need to update the name in your existing JSON reports to maintain compatibility. For more information, refer to our FAQ topic.
Graphics Analyzer 5.5
There are no new features in this release.
Mali Offline Compiler 7.1
Get started
Known issues
Streamline
- SDDAP-9658 - Device reboots while running gatord as root.
Refer to the latest FAQs for all known issues and workarounds.
Arm Mobile Studio: 2020.0 February 28, 2020
What's new in 2020.0
Arm Mobile Studio is a suite of performance analysis tools that enables Android application developers to detect performance bottlenecks in their software and rendering through analysis of performance counters and graphics API traces.
- Streamline 7.2, to profile application performance.
- Performance Advisor 1.0, to generate at-a-glance application performance summary reports.
- Graphics Analyzer 5.5, to debugging graphics API usage.
- Mali Offline Compiler 7.1, to perform static analysis of GPU shader programs.
This is the first release of Performance Advisor, an data analysis tool that can post-process a Streamline data capture from a Mali system to provide an at-a-glance HTML report that summarizes the application performance characteristics and provides advice about where to optimize.
System Requirements
- Windows 10
Arm Mobile Studio 2020.0 introduces the following the following changes and updates compared to Arm Mobile Studio 2019.2.
- Windows installer adds Performance Advisor and Mali Offline Compiler to the PATH.
- Windows installer associates the
.mgd
file extension with Graphics Analyzer. - All tools updated to use the latest OpenJDK Java 11 JVM.
Streamline 7.2
- Support for Cortex-A34 and Cortex-A77 CPUs.
- Support for Mali-G57 and Mali-G77 GPUs.
- Support for selecting from multiple connected devices in
gator_me.py
This release is the first release of Performance Advisor.
- Includes Performance Advisor for data analysis and report generation.
- Includes a light-weight interceptor that can provide API-level metrics and screenshots, for low run-time overhead.
- Support for API capture on Android 10 devices, including support for using an OpenGL ES layer driver.
Note: For Android 10 the recommended interception method is to use layer drivers for both OpenGL ES and Vulkan. The legacy method of bundling the interceptor inside your application APK is unreliable.
- Updated to the latest Khronos
glslangValidator
SPIR-V cross-compiler build, for improved Vulkan language support and bug fixes. - Improved error forwarding from the Khronos
glslangValidator
for Vulkan source shaders that fail to compile in to SPIR-V, showing the error messages in themalioc
output report.
Get started
For Arm Mobile Studio Starter Edition you can raise queries and support issues relating to both the tools and general performance analysis on the Arm Community website.
Known Issues
The following known issues are present in this release:
Graphics Analyzer
- MGD-4152: Linux build host tool GUI panels can fail to respond to mouse wheel events.
- MGD-3735: Debug frame capture views (overdraw map, shader map) can fail for Unity applications.
OSC-485: Invoking
malioc
on macOS 10.15 (Catalina) returns the following security warning, because the binary is not in the ".app" format:
"malioc" cannot be opened because the developer cannot be verified.
You can verify the integrity of the binary by using this command in a Terminal window:
spctl -a -vv malioc
Gatekeeper checks can be disabled by manually removing the
> malioc: rejected (the code is valid, but does not seem to be an app)
> origin=Developer ID Application: ARM Ltd (S345482SL3)com.apple.quarantine
flag from the installed Mali Offline Compiler binary. Open a Terminal window, and run the following commands to disable gatekeeper:cd /Applications/Arm_Mobile_Studio_2020.0/mali_offline_compiler/
sudo xattr -d com.apple.quarantine malioc
Refer to the latest FAQs for further details.
Arm Mobile Studio: 2019.2 November 21, 2019
What's new in 2019.2
Arm Mobile Studio is a suite of performance analysis tools enabling Android application developers to detect performance bottlenecks in their software and rendering through analysis of performance counters and graphics API traces.
- Streamline 7.1, for profiling application performance.
- Graphics Analyzer 5.4, for debugging usage of graphics APIs.
- Mali Offline Compiler 7.0, for static analysis of GPU shader programs.
Note: The macOS package for Arm Mobile Studio was updated on November 21st, to provide an essential fix to Graphics Analyzer. If you were affected by this, download the latest version here.
System Requirements
Arm Mobile Studio is supported on 64-bit versions of the following host platforms:
- Windows 10
- macOS 10.11 (el Capitan) or newer
Arm Mobile Studio 2019.2 introduces the following the following changes and updates compared to Arm Mobile Studio 2019.1.
- Mali Offline Compiler added to the studio package, enabling static analysis profiling of OpenGL ES and Vulkan shader programs, as well as OpenCL kernels.
- Device connection: Non-root single application profiling Android device setup provided via a new
aga_me.py
Python script, which is necessary to run the Graphics Analyzer Daemon inside the application security sandbox.
The following features are deprecated and will be removed in Arm Mobile Studio 2020.0:
- Android Daemon APK: The daemon APK is deprecated in this release; it is replaced by the command line daemon run via the
aga_me.py
script, in order to correctly function within the target application's Android security sandbox. - Trace replay: The Trace Replay feature is deprecated in this release; no replacement is planned. More capable open source alternatives such as PATrace (OpenGL ES) and VKTrace (Vulkan) are available.
- GPU Support: Mali-G52 and Mali-G76 support has been added.
- GPU Support: Bifrost GPU static analysis reporting more accurately reflects GPU pipelines and performance.
The following features have been removed since the previous release:
- Shader binary shader generation is no longer supported; use the on-device driver to generate program binaries.
- Mali-400 series and Mali-T600 series GPUs are no longer supported.
- Reported performance statistics now always use the latest driver for each GPU.
Streamline 7.1
This release includes the following feature enhancements:- Device connection: Non-root single application profiling Android device setup is now enabled using a new
gator_me.py
Python script, replacing the prototypegatorme.bat
andgatorme.sh
scripts. - Device connection: Mali GPU is now reliably auto-detected, so users no longer need to manually specify this on the gator command line when connecting to the device.
- Timeline view: Built-in counter templates will now handle arbitrary numbers of CPU clusters, and will no longer emit duplicate charts for the first cluster.
- Timeline view: Chart title column now auto-sizes to the required width for the enabled counters when a capture is opened.
The following features are deprecated in this release and will be removed in Arm Mobile Studio 2020.0.
- Device connection: Kernel-mode captures using
gator.ko
are deprecated in this release; users should switch to user-mode captures which use the underlying Linux Perf infrastructure.
Get started
Known Issues
Graphics Analyzer
- The Graphics Analyzer device connection wizard does not work for non-root Android profiling. Use the supplied
aga_me.py
Python script to set up the on-device components. See Get started with Graphics Analyzer for further details. - The Graphics Analyzer system-wide Android profiling setup process does not correctly set up the Vulkan interceptor, and it will fail on some devices. Use single application interception instead.
- The Graphics Analyzer capture does not show texture updates from partial surface replacement; e.g. using
glTexSubImage2D()
. - The Graphics Analyzer capture does not support tracing applications using
GL_EXT_disjoint_timer_query
. - Shader compilation, used for static analysis reporting, can fail if the host locale uses "," as a decimal separator. It is possible to force an alternative locale by setting the environment variable
LANG
to the value "C". -
Graphics Analyzer does not intercept API calls from applications containing native C++ code on devices running Android 10(Q). The interceptor starts normally, but shuts down after the application starts, there are no error messages. If you are able to modify the activity source code of your application, you can workaround this issue by moving the 'System.loadLibrary()' call from the start of the main activity to inside the Native C++ activity constructor. Call the load method after the 'super.onCreate()' call in the onCreate method:
public class YourNativeActivity extends NativeActivity {
@Override
protected void onCreate(Bundle savedInstanceState) {
// Call super-class onCreate first
super.onCreate(savedInstanceState);
// Load interceptor second
try {
System.loadLibrary("AGA");
} catch (UnsatisfiedLinkError e) {
e.printStackTrace();
- Mali Offline Compiler only supports OpenCL kernels using version 1.x features. Compiling kernels using OpenCL 2.0 features is not supported, even for GPUs that would support OpenCL 2.0 when using the production drivers.
Streamline
- The Streamline connection wizard does not work for non-root Android profiling. Use the supplied
gator_me.py
Python script to set up the on-device components. See Get started with Streamline for further details.
