DP9060000-SW-99002-r4p0-00rel0.gz Open Source Mali-DP Kernel device driver (Released on 4 Apr 2019) 347 KB
DP9060000-SW-99002-r3p2-00rel0.tgz Android Display Device Driver (Released on 29 Dec 2017) 246 KB
DP9060000-SW-99002-r3p1-01rel0.tgz Android Display Device Driver (Released on 29 Sep 2017) 239 KB
DP9060000-SW-99002-r2p1-00rel0.tgz Android Display Device Driver (Released Feb 2016) 124 KB
DP9060000-SW-99002-r0p0-01rel0.tgz Android Source Code Kernel Device Driver (Released on 4 Mar 2014) 74 KB
Open Source Mali-DP ADF Kernel Device Drivers
Source code for Mali Display Processor Kernel Device Drivers under GPLv2 licence
The Linux version of the Mali-DP Device Driver provides the low-level access to the Mali-DP series Display Processors. Some of these components are being made available under the GPLv2 licence.
This page provides access to the source packages from which loadable kernel modules can be built.Note that these components are not a complete driver stack. To build a functional Android HWComposer you need access to the full source code of the Mali-DP DDK, which is provided under the standard Arm commercial licence to all Mali-DP customers.
The open source drivers provided on this page are designed to run with a version-compatible release of the Mali-DP DDK. By releasing them under the GPLv2 licence we hope to make it easier to include Mali DPU drivers on any Linux or Android platform.
