Comprehensive tools suite to achieve best performance on server-class Arm-based platforms
End-to-end workflow from quickly getting started to advanced optimization for your workloads
Evaluate
What's in Arm Allinea Studio?
Arm Allinea Studio includes:
  1. Arm C/C++ Compiler
    Linux user-space compiler, tailored for HPC and scientific codes, with support for latest C, C++ and OpenMP standards and tuned for leading server-class Arm-based platforms.
  2. Arm Fortran Compiler
    Built on the PGI open source Flang front-end and the LLVM based optimization and code generation back-end. It has wide Fortran application coverage and generates optimal code on 64-bit Armv8-A based platforms.
  3. Arm Performance Libraries
    Optimized standard core math libraries for high-performance computing applications on Arm processors.
  4. Arm Forge
    Arm Forge combines an industry-leading debugger, Arm DDT, and an out-of-the-box-ready profiler, Arm MAP.
  5. Arm Performance Reports
    A low-overhead tool that produces one-page text and HTML reports summarizing and characterizing both scalar and MPI application performance.
Allinea Studio Editions Quick Reference
Feature Essential HPC Starter HPC Professional
Arm C/C++ Compiler Yes Yes Yes
Arm Fortran Compiler Yes Yes Yes
Arm Performance Libraries Yes Yes Yes
Arm Forge (with Arm DDT and Arm MAP)
Debugging and Profiling - Process limitation Multi-threaded Up to 32 MPI processes Up to 64 MPI processes
Debugging and Profiling - Node limitation 1 node 1 node Up to 4 nodes
For profiling and debugging HPC applications with more than 64 MPI processes and/or running on more than 4 Arm nodes, you will have to buy Arm Forge and Arm Performance Reports separately.
Help and support
Get in touch if you have questions, doubts or want to raise an issue. The vast majority of requests are answered within a single working day because we care about keeping you and your team successful.
Get support
