Getting Started
Arm SystemC Cycle Models simplify virtual prototype creation. Models that are IEEE std. 1666-2011-compliant allow you to rapidly assemble systems and integrate other Accellera SystemC and Transaction Level Modeling (TLM) component models to create accurate virtual prototypes.
Because models are the key to creating a virtual prototype, Arm supports a wide range of models in a variety of formats including:
  • Flexible SystemC model support for easy creation and integration
  • High performance cycle-accurate and implementation-accurate models compiled by Cycle Model Studio
  • Verilog and VHDL co-simulation with leading RTL Simulators
Platform Debug
Assembling system models is only part of the solution: the key lies in the ability to execute the prototype, examine the behavior of the system, and analyze key metrics. Arm Cycle Models provide debug interfaces tailored for both hardware and software engineers. You have full visibility and execution control of your design. Software engineers are able to view code, control the simulation at clock edge granularity, and examine registers and memories. Hardware engineers can examine signals, dump waveforms, and trace execution through the system. Run-time performance profiling gives you immediate feedback on system behavior during execution.
Architectural Analysis
Development and analysis of system architecture requires the accuracy to model key system characteristics, especially with complex bus architectures and multi-core communications models. Arm Cycle Models provide the accuracy, performance, and flexibility to model complex systems and perform the analysis required to make critical design decisions. Instead of ad-hoc model approximations and paper-and-pencil calculations, architects can now prove their design assumptions before committing to the design implementation. The unique benefits for architectural analysis enable first-turn success of your SoC:
  • Create cycle-accurate system models required for detailed architectural analysis and explore the performance impact of hardware/software trade-offs
  • Measure interconnect performance of complex bus architectures using actual system behavior to drive traffic
  • Quickly and easily make changes and explore design space alternatives before committing to an implementation
Hardware and Software System Validation
System validation requires the ability to model the entire system working together, and provide accurate models of both the hardware and software. Cycle-accurate virtual prototypes provide a way to develop and validate software before committing to physical hardware implementations. Effective driver and firmware development requires the detail and performance that is provided by Arm. The benefits for hardware/software system validation provide insight:
  • Speed system integration time by debugging your software on virtual platforms before physical prototypes are available
  • Reduce risk by validating hardware implementations using actual system software
  • Eliminate hardware physical prototype availability as a bottleneck to software development
  • Accelerate the process of debugging, implementing hardware or software changes, and then re-executing the system.
Accurate Models from Arm IP Exchange
Arm Cycle Model solutions leverage models from Arm IP Exchange. This web portal enables around the clock access to Arm IP. Models can be easily configured, built, downloaded, and managed, then integrated directly into a SystemC system. The benefits of Arm IP Exchange are numerous:
  • Configuration — IP Exchange understands the valid configuration options for each piece of Arm IP and only permits compatible combinations of these options to be chosen.
  • Quality — Models are generated in a "clean" environment that is proven and continually regression tested. Arm IP Exchange understands the dependencies between the model and SystemC to ensure compatibility.
  • Usability — Models are configured using a short series of questions, which automatically adapt as answers are given, to ensure that only valid configurations are built. No RTL or design knowledge is required to configure or build a model.
  • Enhanced Satisfaction — Arm IP Exchange is available 24/7 allowing you to configure the model as and when you need it. You can easily check on the status of any model you requested to be automatically built.
  • IP Management — Arm IP Exchange maintains a secure history of user models and automatically issues a notification when a new revision or model is available. This secure history mechanism enables you to leverage IP and configurations that are used elsewhere within your organization.
Get support
Community Forums
Not answered Where do I find presentations and photos from SC'18? 2 votes 4502 views 0 replies Started 1 years ago by John Linford Answer this
Suggested answer How do I exclude a Pack file from my build so I can replace with modified version in my folder? 0 votes 46 views 2 replies Latest 5 hours ago by Milorad Cvjetkovic Answer this
Suggested answer USB Camera interface using keil IDE 0 votes 213 views 6 replies Latest 5 hours ago by MHansra Answer this
Suggested answer translation table APTable permission problem
  • Cortex-A57
  • Armv8-A
  • Linux
0 votes 34 views 1 replies Latest 6 hours ago by 42Bastian Schick Answer this
Not answered PCE is failed to find the DAP using DSTREAM-ST in DS-5
  • DS-5 Development Studio
  • DSTREAM
0 votes 15 views 0 replies Started 8 hours ago by jerry.xin Answer this
Suggested answer How to recover the Keil after uninstalling the LIC? 0 votes 95 views 3 replies Latest 9 hours ago by Andy Neil Answer this
Not answered Between osKernelInitialize() and osKernelStart() 0 votes 29 views 0 replies Started 9 hours ago by zunda Answer this
Discussion Looking for activation code of DS-5 Community Edition
  • Tool Licensing
  • DS-5 Community Edition
0 votes 21716 views 20 replies Latest 10 hours ago by Nouchi Answer this
Not answered Regarding Visibility of Multi Master ACE-Lite System 0 votes 23 views 0 replies Started 11 hours ago by RajaAC Answer this
Answered ARM/THUMB instructions that change execution path?
  • Thumb
0 votes 61131 views 77 replies Latest 11 hours ago by jakebunt Answer this
Not answered ACE-Lite 0 votes 14 views 0 replies Started 11 hours ago by Ishan Answer this
Suggested answer C++ header is requesting Rogue Wave
  • Keil MDK
0 votes 2196 views 9 replies Latest 12 hours ago by Tim Scherr Answer this
Not answered Where do I find presentations and photos from SC'18? Started 1 years ago by John Linford 0 replies 4502 views
Suggested answer How do I exclude a Pack file from my build so I can replace with modified version in my folder? Latest 5 hours ago by Milorad Cvjetkovic 2 replies 46 views
Suggested answer USB Camera interface using keil IDE Latest 5 hours ago by MHansra 6 replies 213 views
Suggested answer translation table APTable permission problem Latest 6 hours ago by 42Bastian Schick 1 replies 34 views
Not answered PCE is failed to find the DAP using DSTREAM-ST in DS-5 Started 8 hours ago by jerry.xin 0 replies 15 views
Suggested answer How to recover the Keil after uninstalling the LIC? Latest 9 hours ago by Andy Neil 3 replies 95 views
Not answered Between osKernelInitialize() and osKernelStart() Started 9 hours ago by zunda 0 replies 29 views
Discussion Looking for activation code of DS-5 Community Edition Latest 10 hours ago by Nouchi 20 replies 21716 views
Not answered Regarding Visibility of Multi Master ACE-Lite System Started 11 hours ago by RajaAC 0 replies 23 views
Answered ARM/THUMB instructions that change execution path? Latest 11 hours ago by jakebunt 77 replies 61131 views
Not answered ACE-Lite Started 11 hours ago by Ishan 0 replies 14 views
Suggested answer C++ header is requesting Rogue Wave Latest 12 hours ago by Tim Scherr 9 replies 2196 views
