Sample Arm Cortex-A53 Cycle Models reference platform
Getting Started
Virtual prototypes play a vital role in the design and analysis of system on chip designs. In order to maximize the time spent being productive with virtual prototypes and minimize the time required to create them, Arm supplies a rich library of Cycle Models reference platforms. These extensible virtual prototypes come complete with models, system information and software to enable designer productivity within minutes of download.
Access reference platforms
Cycle Models reference platforms features
  • Pre-built example reference platforms featuring advanced technology such as the Cortex-R82 and Cortex-A55 processors
  • 100% accurate models for critical performance elements including processors, fabric and memory controllers
  • Arm Fast Model representations to enable application software development at millions of instructions per second
  • Bare-metal software package to initialize components and enable easy customization and benchmarking
  • Linux OS packages including source code
Simple Customization
Cycle Models reference platforms are designed to be useful immediately after download, but not all SoCs are the same. To better model the behavior of your actual SoC, reference platforms can also customize your reference platform. Reconfigure or replace IP blocks, or add additional blocks and subsystems to the system. Designers are able to take advantage of the complete Arm model ecosystem including models from Arm IP Exchange, models compiled from RTL using Cycle Model Studio or handwritten models in C/C++ or SystemC.
Source code is also provided for all software components to enable easy customization. Reference platforms minimize the setup tasks typically associated with SoC design and enable engineers to focus their efforts in more productive areas.
Architectural Analysis
Cycle Models reference platforms are ideally suited for accurate architectural analysis. They contain 100% accurate models compiled directly from RTL and instrumented for interactive design, debug and analysis. Cycle Models reference platforms let you see the behavior of the actual silicon months before it is built. This enables the designer to make architectural decisions with confidence. They take advantage of all of SoC Designer's architectural analysis and visualizations tools to give the designer unmatched insight into actual SoC behavior.
System Performance Optimization
Although many benchmarks execute on a bare-metal system, a large number of them require an OS to be present. Traditionally this presents a problem because the cycle accurate models which are so beneficial for bare metal benchmarks and optimization are simply too slow to be used with an OS. Even booting an OS on a platform containing only cycle accurate models can take days.
Cycle Models reference platforms for the Linux and Android OS solve this problem by using Arm's Swap & Play technology. This enables the OS to boot in seconds and get to the software area of interest for performance analysis. The system representation is then swapped to be 100% accurate (for all or just part of the system) and execution continues. This technique enables accurate benchmarking and optimizations.
Unmatched IP Integration
Your SoC design doesn't just use IP from a single vendor. Your virtual prototype representation shouldn't either. Cycle Models reference platforms can easily accommodate additional third party IP models. These models can either be added to the Cycle Models reference platform or used to replace a delivered component. Future Cycle Models reference platforms will also include select third party IP to further accelerate the integration process.
Get support
Community Forums
Answered Keil MDK 5 – useful links that help getting started 0 votes 2664 views 3 replies Latest 1 months ago by rkopsch Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1643 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1367 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Forum FAQs
  • ARM Community
0 votes 2405 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1275 views 1 replies Latest 3 months ago by Oliver Beirne Answer this
Answered Where should I ask my question?
  • ARM Community
0 votes 11796 views 5 replies Latest 8 months ago by Andy Neil Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1292 views 0 replies Started 1 years ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 2679 views 0 replies Started 1 years ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1795 views 0 replies Started 1 years ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 1648 views 0 replies Started 1 years ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 10724 views 0 replies Started 1 years ago by Annie Answer this
Answered Forum FAQs
  • ARM Community
0 votes 6613 views 0 replies Started 1 years ago by Annie Answer this
Answered Keil MDK 5 – useful links that help getting started Latest 1 months ago by rkopsch 3 replies 2664 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 1643 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 1367 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 2405 views
Answered Forum FAQs Latest 3 months ago by Oliver Beirne 1 replies 1275 views
Answered Where should I ask my question? Latest 8 months ago by Andy Neil 5 replies 11796 views
Answered Forum FAQs Started 1 years ago by Annie 0 replies 1292 views
Answered Forum FAQs Started 1 years ago by Annie 0 replies 2679 views
Answered Forum FAQs Started 1 years ago by Annie 0 replies 1795 views
Answered Forum FAQs Started 1 years ago by Annie 0 replies 1648 views
Answered Forum FAQs Started 1 years ago by Annie 0 replies 10724 views
Answered Forum FAQs Started 1 years ago by Annie 0 replies 6613 views
