Release History
The latest Fast Models release version is reported at the top right of this page.
Details on What's New, and links to the Release Notes are provided below.
Subscribe to the Changelog RSS feed to receive alerts when future Fast Models releases become available.
Fast Models
Version 11.15
Released: June 29, 2021
  • Fast Models: 11.15 June 29, 2021
    What's new in 11.15
    New features and enhancements
    • The following models have been added to the Fast Models Portfolio:
      • Cortex-A78AE
      • Cortex-A510
      • Cortex-A710
      • Neoverse N2
      • Neoverse V1
      • Ethos-U65
      • CMN-700 r0p0
      • MMU-700
    • An AEMv8R64 source example has been added to the Fast Models Portfolio.
    • The Accellera SystemC version has been updated to v2.3.3.
    • Generic Graphics Accelerator (GGA) now supports AFBC in both GGA only mode (callOnTargetAPI 0) and GGA+GRM2 mode (callOnTargetAPI 2) for the Bifrost GPU architecture. GPU drivers and graphics stacks can now be compiled with AFBC=y in the configuration.
    Deprecated and removed features
    • AEMv8-A platforms are deprecated and a selected list of them has been ported to AEMvA. In the next release, all the AEMv8-A platforms will be removed. For more information, contact support@arm.com.
    • The Fastline plug-in is end-of-life and has been removed.
    • Release Note
  • Fast Models: 11.14 March 18, 2021
    What's new in 11.14
    • The Ethos-U55 NPU model now supports Windows hosts.
    • The CMN-600AE model has been added to the Fast Models portfolio.
    • The simgen and sgcanvas targets related to Model Shell (TARGET_MAXVIEW and TARGET_ISIM_DEPRECATED) are no longer supported and have been removed.
    • The Fastline plug-in is deprecated and will be removed in a future release.
    Advance notice
    The next Fast Models release will include changes to the product licensing features. Instructions will be provided in the release notes.
    • Release Note
  • Fast Models: 11.13 December 09, 2020
    What's new in 11.13
    • Support has been added for the following CPUs and System IP:
      • Cortex-A78C
      • Ethos-U55 NPU, currently for Linux hosts only.
      • Cortex-A78AE and Cortex-R82 Fast Models and FVPs are available as add-on packages on request.
    • The Corstone-300 FVP contains the Ethos-U55 model and is available free of charge at Arm Ecosystem FVPs.
    • The Cortex-M55 model supports Custom Datapath Extension (CDE).
    • System Register trace sources have been extended to capture CRm, CRn, opc0, opc1, and opc2 fields.
    • Visual Studio 2019 support has been added.
    • FastRAM is a new optimization feature which can bring significant speed improvements.
    • Model Shell and the related SimGen and System Canvas targets TARGET_MAXVIEW and TARGET_ISIM_DEPRECATED are deprecated.
    • AEMv8-A platforms are deprecated and will soon be replaced by AEMvA platforms.
    Advance notice
    Windows support will be added for the Ethos-U55 NPU model in a future release.
    • Release Note
  • Fast Models: 11.12 September 22, 2020
    What's new in 11.12
    • Added support for the following CPUs and System IP:
      • Cortex-M33 r1
      • MMU-700
      • CMN-650
      • GIC-600AE
    • Neoverse N2, Cortex-R82, and GIC-700 models are at beta stage and are not included in the main package.
    • VirtioNet has been enhanced to expose Hostbridge CADI and Iris debug interfaces.
    • Added new command-line options to install the package without user interaction.
    Removed support for PyCADI. It has been replaced by iris.debug.
    Advance notice
    Support for Android 10 in GGA/GRM will be available in a future release pending an upstream patch.
    • Release Note
  • Fast Models: 11.11.1 July 14, 2020
    What's new in 11.11.1
    • Fixed a fatal error when connecting the GIC-600 in a multichip configuration.
    • Enabled SVE2 in the Foundation Platform and Base Platform RevC FVPs.
    • Corrected an occasional internal fault (segfault) at model startup.
    • Release Note
  • Fast Models: 11.11 June 09, 2020
    What's new in 11.11
    • Support for Custom Datapath Extension (CDE) for Armv8-M and example plugins for generating custom instructions for Cortex-M33.
    • Support for Cortex-A78 and Cortex-X1 CPUs.
    • The supported Accellera SystemC version is now 2.3.3.
    • If you are using floating licenses, this version of Fast Models requires FLEXnet server version 11.16.6.0 or later.
    Windows 7 support has been removed.
    • Release Note
  • Fast Models: 11.10 March 12, 2020
    What's new in 11.10
    • Support for the Cortex-M55 CPU
    • Support for GCC 7.3 on Ubuntu 18.04 LTS and RHEL 7
    • Support for the Corstone SSE-300 platform
    • Generic Graphics Accelerator (GGA) supports Android 9
    • Release Note
  • Fast Models: 11.9 November 27, 2019
    What's new in 11.9
    • Support for Armv8.6-A features
    • Beta support for GCC 7.3
    • Wayland client support has been added to GGA/GRM
    • Python support policy has been aligned with the official Python release schedule
    • FVPs are built with compilers gcc-6.4 and VisualStudio 2017.
    • Windows 7 support is deprecated
    • Accellera SystemC version 2.3.1 support is deprecated
    • Ubuntu 14.04 support is deprecated
    • GCC 5.x compiler support is deprecated
    • Release Note
  • Fast Models: 11.8.1 October 09, 2019
    What's new in 11.8.1
    • Arm collects anonymous product usage analytics. This feature can be controlled by command-line options or an environment variable.
    • Various bug fixes.
    • Release Note
  • Fast Models: 11.8 September 05, 2019
    What's new in 11.8
    • The default value of 'cache_state_modelled' on the CMN600 model has changed from true to false.
    • Support for multi-chip operation added to the GIC-600 model.
    • PSTATE tracing added to models of DynamIQ cores to determine why prequests are accepted or denied.
    • Support added for ImpDef RAS registers in Neoverse-N1 model.
    • zlib updated to version 1.2.11.
    • Release Note
  • Fast Models: 11.7.1 June 26, 2019
    What's new in 11.7.1
    • A new port, chip_id, has been added to all GIC600 model versions.
    • A new parameter, redistributor-power-managed-by-pwrr, has been added to the GIC600 model.
    • Release Note
  • Fast Models: 11.7 May 31, 2019
    What's new in 11.7
    • Updated End User License Agreement (EULA).
    • Support for Cortex-A65 and Cortex-A77 Fast Models and platforms.
    • Support for Cortex-M33 and AEMv8M coprocessor.
    • Support for Component Aggregation Layer (CAL) in the CMN-600 model.
    • Full support for VC2017.
    • Armv8.5-A support at Release quality.
    • Release Note
  • Fast Models: 11.6.1 March 25, 2019
    What's new in 11.6.1
    Added support for Cortex-A65AE and Cortex-A76AE Fast Models and platforms.
    • Release Note
  • Fast Models: 11.6 March 01, 2019
    What's new in 11.6
    • Revised End User License Agreement (EULA).
    • Support for Neoverse N1 and E1 CPUs and platforms.
    • Support for VC2017 at Alpha quality.
    • Support for Armv8.5-A at Release quality, except for complete Memory Tagging (MTE) functionality.
    • Support for Armv8.1-M, including the Helium vector extensions.
    • Model Shell and the related SimGen target (TARGET_MAXVIEW) are deprecated.
    • CADI is deprecated but continues to exist alongside Iris as an optional debug API until end-of-life and removal in May 2020.
    • Release Note
  • Fast Models: 11.5 November 23, 2018
    What's new in 11.5
    • General release of the Iris debug API, which replaces the CADI debug API.
    • Fast Models now uses SystemC 2.3.2.
    • Support for the ARMv8.5 (Beta) architecture.
    • The PCI subsystem now includes an AHCI controller model that can be used to load disk images.
    • The FVP_Base_RevC-2xAEMv8A example platform now contains an AHCI controller.
    • Timing annotation latency fields have been added to cache MTI trace sources.
    • DMI regions greater than 4GB in size are now used correctly inside the AMBA-PV bridges.
    • A problem with local time when using VFP instructions with Cortex-M models has been fixed.
    • Support for GCC-4.8.3, GCC-4.8.4, and VC2013 has been removed.
    • The FVP_Base_AEMv8A-AEMv8A-DP550-V61 example platform has been removed.
    • Release Note
  • Fast Models: 11.4.2 September 13, 2018
    What's new in 11.4.2
    • Generic Graphics Accelerator (GGA) and GPU models have been restored.
    • Added support for Mali-G76 register model.
    • Release Note
  • Fast Models: 11.4 June 21, 2018
    What's new in 11.4
    • New CTModels for Cortex-A76, with several new example FVP_Base platforms.
    • New CTModel for Cortex-M35P and new Build_Cortex-M35P example FVP_MPS2 platform.
    • Added support for compiler GCC-6.4.0.
    • GGA (Generic Graphics Accelerator) and GRM (Graphics Register Model) are not supported in this release.
    • The zstdint.h and zinttypes.h headers are deprecated. Use the standard cstdint and cinttypes files instead.
    • Release Note
  • Fast Models: 11.3 February 28, 2018
    What's new in 11.3
    • Support for the ARMv8.4 architecture.
    • Support for the Mali-D71 display processor.
    • New features in GGA:
      • IRQ trace support for all GRM variants.
      • Support for Vulkan GRM (Beta).
      • Support for Mali Graphics Debugger (MGD) (Beta).
    • ToggleMTIPlugin has been added to help to register and unregister MTI callbacks.
    • DRAM has been enhanced to accept routing of addresses in the 52-bit address range.
    • The -f parameter in SVP Platforms now means --config-file instead of --fast to make it consistent with existing FVPs.
    • The ARM926, ARM968, ARM1136, and ARM1176 core models have been removed.
    • Release Note
  • Fast Models: 11.2 November 21, 2017
    What's new in 11.2
    • Support for the ARMv8.4 (Beta) architecture.
    • New MMU-600 model.
    • New PipelineModel plug-ins:
      • CortexA53PipelineModel. This is an approximation of the CortexA53 pipeline.
      • InOrderPipelineModel. This is a simplified 4 stage single issue CPU pipeline model, with source code to help create new PipelineModel plug-ins.
      • Vulkan support.
      • AFBC encoding support.
      • New Mali-G51 (Beta) GPU model.
    • A PVBusLogger has been added to the downstream port of interconnect components except for CCI400.
    • New Virtio Ethernet device model, VirtioNetMMIO.
    • Support for PPU v1.1.
    • New source example platforms:
      • SGM-775.
      • SGI-575.
    • Model Shell and the related SimGen target TARGET_MAXVIEW, are deprecated.
    • TarmacTraceV8 has been removed. The TarmacTrace plug-in has been enhanced to replace it.
    • Release Note
  • Fast Models: 11.1 August 31, 2017
    What's new in 11.1
    • Support for breakpoints for vector catching has been added to the models of M-profile CPUs.
    • Partial support for the architectural debug feature, Instrumentation Trace Macrocell (ITM), has been added to the Fast Models of M-profile CPUs that support it.
    • The architecture-version parameter has been removed from the AEMv8M core model.
    • Addition of new fields to the MMU_TRANS MTI trace source.
    • New features in GGA (generic Graphics Accelerator):
      • Support for Vulkan (Beta).
      • Performance improvements.
      • New ports supported for GRM.
    • New ScalableVectorExtension plug-in enables AEMv8-A processor models to execute SVE instructions.
    • RealTimeLimiter default setting has changed from true to false.
    • DynamIQ(FCM) clusters implement partial powerdown of L3 Cache, with new parameters.
    • Support for Visual Studio 2015 - Update 3.
    • VFS has been removed. Use Virtio P9 instead.
    • The ARM926, ARM968, ARM1136, and ARM1176 models are deprecated.
    • Release Note
  • Fast Models: 11.0 June 06, 2017
    What's new in 11.0
    • Fast Models internal scheduler is deprecated in favour of SystemC:
      • All of the ISIM executables produced by simgen are based on SystemC.
      • The TARGET_ISIM build target is dropped and several new build targets are introduced.
    • New CTModels for Cortex-A55 and Cortex-A75 with several new example FVP_Base platforms.
    • Introduction of DynamIQ(FCM) FVP_Base Platforms consisting of clusters of Cortex-A55 and Cortex-A75 CTModels, in various configurations.
    • Updates to Cortex-R52 parameters and registers.
    • New IDAU model and updates to names of parameters in FVPs to refer to it.
    • New CMN-600 model.
    • New GIC-600 model.
    • New SMMUv3AEM architectural model which implements the SMMUv3.0 and SMMUv3.1 architectures.
    • Mali-V550 and Mali-V61 model parameters have been changed to better reflect RTL configurability.
    • New Mali-G71 GPU model which can work with or without GGA, to help graphics software stack verification.
    • New FVP_Base_AEMv8A-AEMv8A-CMN600 platform.
    • Rate-limiter has been turned to OFF by default on FVP platforms.
    • New P-Channel power management protocol.
    • New AEMv8A core personalities feature allows you to configure AEM instances in a platform for a specific implementation at model startup.
    • New Fastline plug-in enables you to use Streamline Performance Analyzer to analyze software running on Fast Models.
    • use_instr_cnt_as_timestamp command-line parameter has been added to TarmacTrace and TarmacTraceV8 to alow you to use the instruction count instead of the simulation time as the timestamp in the trace.
    • TarmacTraceAEM plug-in has been removed.
    • Support for Linux compiler GCC-4.7 has been removed.
    • Release Note
