DR12 and X11 Display Drivers
Open Source Mali GPUs Linux EXA/DR12 and X11 Display Drivers
Source Code For Mali GPUs Linux X11 Display Drivers Including EXA/DRI2 Module Under The MIT License
This archive provides the source code to integrate the Mali GPU DDKs into the X11 environment. More specifically it provides the source code for the X11 display driver and for the EXA/DRI2 modules (EXA provides 2D integration hooks while DRI2 enables 3D acceleration with the Mali GPU DDK).
Note that these components are not a complete driver stack. To build a functional OpenGL ES or OpenVG driver you need access to the full source code of the Mali GPU DDK, which is provided under the standard Arm commercial licence to all Mali GPU customers. For a complete integration of the Mali GPU DDK with the X11 environment refer to the Integration Guide supplied with the Mali GPU DDK.
The open source code provided on this page is designed to run with a version-compatible release of the Mali GPU DDK (currently r2p1). They also require the MaliDRM component also available from this page. By releasing this software under the MIT licence we hope to make it easier to include Mali GPU drivers in any Linux platform.
FEATURES & BENEFITS
The X11 display driver and EXA/DRI2 module handle:
  • Linux frame buffer device (FBDEV) integration
  • Integration with 2D acceleration architecture
  • X11 native resources such as surfaces
  • Communication with the DRM module
DX910-SW-99003-r10p0-00rel0.tgz EXA/DR12/X11 display drivers r10p0-00rel0 (Released on 26th September 2019) 24 KB
DX910-SW-99003-r9p0-01rel0.tgz Released 17 Sep 2018 26 KB
DX910-SW-99003-r8p1-00rel0.tgz EXA/DR12/X11 display drivers r8p1 released on 11th January 2018 26 KB
DX910-SW-99003-r8p0-01rel0.tgz Released 15 Sep 2017 26 KB
DX910-SW-99003-r7p0-00rel1.tgz Released 20 Jan 2017 23 KB
DX910-SW-99003-r7p0-00rel0.tgz Released 13 Sep 2016 23 KB
DX910-SW-99003-r6p2-01rel0.tgz Released 14 Jul 2016 24 KB
DX910-SW-99003-r6p1-01rel0.tgz Released 2 Mar 2016 24 KB
DX910-SW-99003-r6p0-01rel1.tgz Released 13 Jan 2016 24 KB
DX910-SW-99003-r6p0-01rel0.tgz Released 10 Nov 2015 24 KB
DX910-SW-99003-r5p2-00rel0.tgz Released 19 May 2015 24 KB
DX910-SW-99003-r5p1-01rel0.tgz Released 17 Mar 2015 24 KB
DX910-SW-99003-r5p0-01rel0.tgz Released 11 Nov 2014 23 KB
DX910-SW-99003-r4p1-01rel0.tgz Released 07 Jul 2014 23 KB
DX910-SW-99003-r4p0-00rel1.tgz Released 06 May 2014 23 KB
